PSOM help
Old May 27, 2014 | 05:26 PM
mwm6981's Avatar
mwm6981
PSOM help
I have a 1992 F250. The speedometer/odometer were not working so I replaced the PSOM. The new one did not work either. The fuses in the dash are good. I checked the plug and I have volts in pin 4 and 5 of the connector. What could cause the PSOM to not work. Nothing works on it. The LCD screen is blank and the speedometer needle stays at 0
Old May 27, 2014 | 05:50 PM
Eddiec1564's Avatar
Eddiec1564
Battery power is on pin 1( LT green/yellow wire) through fuse #8
Key power is on pin 3 (White/purple wire) through fuse #18
Ground is on pin 2 (pink/orange wire)
Pins 4 and 5 are the VSS(speed sensor) and should not have any DC voltages on it(its AC from the VSS).
Best recheck the fuses, fuse #8 also goes to the dome light and that does short out from heat melting plastic mounts blowing fuse #8 and then the PSOM is dead.
As two PSOMs are not powering up . Recheck the power feed pins I listed above. If they check good, then check the ground wire to the PSOM.
Old May 28, 2014 | 07:07 AM
subford's Avatar
subford
Please clarify this statement.
Should be zero volts with the truck not moving.
Should be 3.5 volts AC @ 30MPH.
Or
Should be 667 Hz @ 30MPH.
paddler65
Jun 27, 2022 11:44 AM
PCaraway
Aug 13, 2018 08:07 PM
BamainCT
May 13, 2016 03:11 PM
MrShake
Aug 24, 2012 09:47 AM
Mil1ion
Electrical Systems/Wiring
Aug 13, 2002 04:32 AM
