Dome Lights - WD40 Trick doesn't work
Old Jun 5, 2007 | 03:45 PM
andrewmh's Avatar
andrewmh
To all:
STEP 1:
Thanks in advance to all for reading and to any who might be able to provide some help.
I have a '98 Eddie Expy, and I've had dome lights that wont turn off since about March of this year. For a while, I had a door ajar light. Not anymore. After reading this forum, I've applied WD40 to the latch on the doors themselves multiple times. I've tried opening and closing the doors, but nothing seems to solve the problem. My solution has been to remove the fuse, but then I can't use my windows.
I'm guessing then, that whichever switch stuck is broken. I'm not really pumped about taking each door apart to find out which one it is. Does anyone know of any method for determining which door is broken in advance?
One last fact: while the dome and other interior lights stay on, the running board lights will turn off as soon as the doors are closed. Do you think I can assume that it is either the window or rear door latch switch?
Does anyone this I'm applying the WD40 wrong?
Thanks again,
Andrew
STEP 2
I tried PB Blaster but that didn't work either. I coated all the latching mechanisms and tried closing the doors multiple times.
Because the running lights don't have a problem turning off, I took a guess that the broken latch was in the liftgate. Bad assumption. After taking the latch mechanism off, and trying to figure out where the plunger switch was, I was still in the dark (or light, I guess). After reattaching, I noticed that closing any one of the doors, liftgate, or rear window, turned the domelight off.
So, there has to be a working switch in each of the doors, liftgate and rear window, or the running boards wouldn't turn off, right?
Given that assumption, I removed the fuse and applied a voltmeter to see if I had a short somewhere. No dice, I read only a really tiny voltage differencial and even that went away.
Two other facts might make a difference. The rear window wiper won't work (leading me to believe the multiswitch might be a problem) and I can't keep wiper fluid in the thing. I haven't watched for leaks, but perhaps they could be related. All I know is that a gallon of fluid lasts less than 24 hours.
Any thoughts?
Thanks in advance for reading this and for any help you could provide.
STEP 3:
I also tried starting the truck and then opening the doors and stuff one by one to see if the warning beep went off. I figured where the warning sound didn't go off, the switch must be stuck. But all the doors, the rear window and the liftgate all made the warning sound go off. I'm starting to think that this problem isn't related to a switch at all.
Anyone have any ideas? Is this a multi-switch problem?
Old Jun 6, 2007 | 12:25 PM
sowder's Avatar
sowder
Is the dome light switch (wheel) working, will It dim the dash lights with the headlights on? will it turn dome light on and off?
Old Jun 6, 2007 | 08:20 PM
al52269's Avatar
al52269
The above member took my words out of my mouth...
Check the Dome Light Switch and see what happends...
1972-34ton
Electrical Systems/Wiring
15
Dec 29, 2018 09:30 AM
mlshelton
Jun 6, 2008 06:14 AM
76f350spercamprspeal
15
Feb 18, 2008 05:14 AM
ReAX
Modular V8 (4.6L, 5.4L)
Mar 25, 2007 09:27 AM
roger dowty
15
Dec 6, 2005 02:44 AM
