Sponsored by: Real Truck
Buzzing Relay!!!!!!
Old Jun 5, 2007 | 12:11 AM
eli98's Avatar
eli98
Buzzing Relay!!!!!!
Hi guys, my dad has an 03 superduty, and was pulling his holiday trailer. He pulled over to check something, and when he returned to the cab he had a buzzing coming from the signal relay under the dash. Its annoying as heck and I can't figure it out. We swapped relays with the one from my truck, to no avail. At wits end here, anyone had this problem? How did you solve it? Would rather not have to pay a Ford tech 80-90 dollars an hour to look for a broken wire or change out a bulb.
Old Jun 5, 2007 | 01:00 AM
eli98's Avatar
eli98
Take To Top
Old Jun 5, 2007 | 07:35 AM
rocket80's Avatar
rocket80
Check out your combo switch(turn/wiper), I think it going bad can cause that.
Old Jun 7, 2007 | 06:15 AM
eli98's Avatar
eli98
Thanks it was the combo switch. $135, and an hour to change it, no more buzzing.
Old Aug 25, 2011 | 09:38 AM
benjamin.cremean's Avatar
benjamin.cremean
out of curiosity, what did this involve? I have the same symptom, and would like to do fix it myself.
Old Aug 25, 2011 | 09:57 AM
raidscsi's Avatar
raidscsi
No buzzing, but I broke the turn signal cancel mechanism, found a spring and black plastic pin on the driver side floorboard the day after it was broken.
Old Aug 25, 2011 | 11:19 AM
benjamin.cremean
Well, my under dash relay buzzes constantly, I took it out thinking, wonder what this does... then my turn signals didnt work so at least I know what it does. the buzzing stops whenever I activate the turn signals or brake lights. So the only relief to my ears is when I am at a stop light or changing lanes ha ha.
Old Aug 25, 2011 | 12:06 PM
Pili's Avatar
Pili
Did you try replacing the relay?
Old Aug 25, 2011 | 12:29 PM
benjamin.cremean
Yea, to no avail. I was hoping that it would be that simple.
Old Aug 25, 2011 | 05:50 PM
benjamin.cremean
on the bright side, I now have a spare.
Old Aug 25, 2011 | 06:27 PM
benjamin.cremean
Just a wonder, but I found this Turn Signal Wiper Lever Multifunction Dimmer Switch | eBay and am wondering if it will fit my 03? it says 97-99 but it looks exactly like what I need.
Mario428
Apr 5, 2014 08:44 PM
sargentmajord
Mar 9, 2014 01:09 PM
BlueScab
18
Jul 2, 2013 09:13 PM
tigwelder
38
Mar 3, 2010 07:40 PM
stroke-of-luck00
Nov 2, 2008 08:58 AM
