Wtf Is This Noise!!!
well i've posted about a buzzing noise from behind my dash when turning the key a while back. i narrowed it down to a relay in the main fuse box in the engine compt. when i take the relay out and turn the key, still a buzz. i replaced the relay thinking it was a bad one and turn the key........still buzzes. next i go digging behing the dash. i find another relay pack with three relays in it. one big blue one, 2 small black ones. i remove the one that was buzzing and turn the key.....still buzzing. it seems somehow these two relays are linked but i have no clue what they are. would one good relay (the new one under the hood) and one bad one behind the dash still cause it to buzz?? when i take both out there is no buzz....
on
im sure they do ground out..on mine..there is a clip thats held on by one mounting bolt..the clip goes though a stit in the plastic cover and there is a spring like end on the inside where the PCM pushes againts it..
jtorsey91
12-06-2015 10:46 AM
