6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
45 cetane rating
Old Jun 4, 2007 | 09:16 AM
rondocycle's Avatar
rondocycle
45 cetane rating
The 6.4 PSD requires a minimum of 45 cetane rating according to the video. Most stations are rated at a minimum of 40. Did the 6.0 have the same requirement? Will running 40 cetane fuel cause problems?
Old Jun 4, 2007 | 03:28 PM
cv67cheng's Avatar
cv67cheng
No one else has reported any problems. The vidoe also conviently mentions that Ford sells cetane booster at the dealership. Wonder what a real world tech can tell us or if it would effect hp/tq of engine.
Old Jun 4, 2007 | 03:38 PM
blackhat620's Avatar
blackhat620
ASTM D975 ULSD fuel is required to have a minimum of 40 cetane, while the ASTM D613 specifies a minimum of 43 cetane. Running lower cetane rating will result in increased white smoke at start up and increased engine noise. Best way to be safe for cetane #'s and lubricity is to run a fuel additive with every tank full. Use DK Power Service or Stanadyne or one of the other diesel fuel additives that contains No Alcohol. DK is a popular choice for the 6.0 and should work equally well in the 6.4L.
Hope this helps
Old Jun 4, 2007 | 03:48 PM
kw5413's Avatar
kw5413
It was said that the 6.0 was designed for optimum performance at 48 cetane. Not a requirement though.....
Old Jun 4, 2007 | 04:30 PM
NS F250's Avatar
NS F250
Nothing new. My uncle is a mechanic at a school bus company and they have a few short buses with 7.3' s. International said the same thing about the 7.3, 45 minimum cetane. They had samples tested by a lab from all the stations around and did not find one that had a cetane of 45 or more. This was with LSD by the way. Couldn't tell ya what ULSD is, but just to be on the safe side, I run Diesel Kleen in every tank as does the bus company.
Old Jun 5, 2007 | 01:03 AM
phredE's Avatar
phredE
As blackhat mentioned the DK has been a popular additive for the 6.0 and seems to help with mileage, power lag, etc. Question I have for the 6.4 is; how sensitive is the Particulate Filter to certain additives? and will these additives cause more frequent regens?
Also, is there any way to do a simple test for cetane with out involving a lab?
Old Jun 5, 2007 | 01:10 AM
blackhat620
If you look on the bottle of DK there is a sticker that says ULSD compliant. In order to use a fuel additive in a 6.4L or any 2007 diesel engine the additive must be ULSD compliant.
I know of no easy cetane test that a consumer could perform.
milsuper
6.7L Power Stroke Diesel
28
Dec 2, 2014 09:45 PM
ljutic ss
Nov 26, 2014 07:58 AM
jayman2
15
Jan 31, 2011 10:28 PM
tholt34
General Diesel Discussion
Jan 8, 2008 09:13 PM
