Sponsored by: Real Truck
AIS filterminder problem
Old Jun 21, 2007 | 11:17 PM
  #61
missouguy's Avatar
missouguy
Originally Posted by tlocklear
missouguy, your mileage sounds pretty good while towing. I just got back from a 1300 mile round trip towing 5K. With the AIS and averaging 65 mph on flatlands (I-95, NC to FL), I got 11.5 mpg on one tankful. Got impatient, juiced it up to 70 mph, mileage dropped to 9.7 mpg on subsequent fillups. BTW, I got a new filterminder from Diesel Power Products and it pulled down to the first mark during the first half of the trip, but hasn't moved any more. If I keep my foot out of it, I may yet be satisfied with the AIS purchase.
I may have to ammend those numbers. Since the switch to the "new" fuel I seem to have dropped about 1 MPG. I usually keep it around 60 when towing.
Frank
Old Sep 1, 2007 | 03:45 PM
  #62
rbaker6336's Avatar
rbaker6336
Originally Posted by dfuser
You will be fine. Just do the zoodad for now or my new way of allowing air in, which does not allow water to directly feed into the intake.
http://dfuser.com/img/ram_air.JPG
Bill
done this work good no more filter minder problems
Old Nov 4, 2007 | 05:42 PM
  #63
NoBite's Avatar
NoBite
Brother, I'm such a noobie. But, if I don't ask, I'll regret it.
You guys talk about "filter minder" problems. I just had the AIS system installed. Within the first week, the air filter light came on and has stayed on. Is this what you are referring to?
Old Nov 4, 2007 | 05:49 PM
  #64
dfuser's Avatar
dfuser
Yep, that is exactly what it is. Yours have the electronic minder feature that turns the light on on the dash.
Old Nov 4, 2007 | 05:57 PM
  #65
NoBite's Avatar
NoBite
Thanks! I won't tell you the grief I've been feeling not knowing why that light came on. After reading this entire thread, I went and looked under the hood. Yep, my filter minder was indicating complete air restriction. I reset it. No more dash light. I bookmarked the filter minder web site for further reading.
Now I need to see if the filter minder will again set off the light when I pull the trailer the next time. I have not done the Zoodad mod or the newly named dfuser mod. I am debating doing one or the other.
Old Nov 4, 2007 | 06:29 PM
  #66
dfuser's Avatar
dfuser
Do the mod, you will not regret it. I'd also do the fender sleeve as well.
Old Nov 4, 2007 | 06:39 PM
  #67
rbaker6336's Avatar
rbaker6336
I done this one http://dfuser.com/img/ram_air.JPG and minder just pulls where you can barely see it
Old Nov 5, 2007 | 04:42 AM
  #68
NoBite's Avatar
NoBite
dfuser, I'm not sure I understand the "fender sleeve" mod. I have pictures of Zoodad and dfuser mods.
Also, thanks rbaker6336 for your picture and testimonial!
Old Nov 5, 2007 | 06:09 AM
  #69
dfuser's Avatar
dfuser
The fender sleeve is a mod that allows you to pick up air from the fender into the AIS system. You do have to make an openning into the side of the AIS. The fender sleeve piece will then fit between the AIS and an openning in the fender.
Old Nov 5, 2007 | 12:37 PM
  #70
NoBite's Avatar
NoBite
dfuser - has anyone posted pictures of this mod? Sounds interesting.
Old Nov 5, 2007 | 05:23 PM
  #71
dfuser's Avatar
dfuser
Here you go:
http://www.dfuser.com/img/foamsleevelargeweb.jpg
Bill
Old Nov 5, 2007 | 06:39 PM
  #72
SpringerPop's Avatar
SpringerPop
A FilterMinder is a very worthwhile tool in determining filter restriction and when to change it. There's a problem in it's use with the AIS, however.
The FilterMinder uses under-hood ambient air as it's "zero-reference" to measure the vacuum on the "clean" or "filtered" side of the filter. When designing it, the company assumed that there would not be a time when the "dirty" or "unfiltered" side of a filter would not have complete free access to unlimited amounts of air, thus it would also be at "ambient" air pressure.
The problem comes into play when the "unfiltered" side of the filter is also subject to a vacuum, but the FilterMinder's "reference" is still at "ambient". This is what is the case with the AIS. The inlet to the housing is too restrictive, and a vacuum develops (reference to "ambient") on the unfiltered side of the media, too. The sleeve above mentioned attempts to solve this problem.
What's attempting to be read is a drop ACROSS the media, which would require that the device have it's reference INSIDE the AIS box, on the "dirty" side.
If I had an AIS, I could jury-rig up something that would put the outside of the FilterMinder at the same reference as the inside of the AIS box. What the company needs to do to solve this is to figure out a way to seal it against atmospheric pressure and have a hose fitting at EACH end, allowing one to plumb it across the filter medium itself.
Pop
Old Nov 6, 2007 | 04:19 AM
  #73
NoBite's Avatar
NoBite
Pop - that is a brilliant analysis! Makes perfect sense to me and addresses the one remaining question I had - - - would the filter minder be equipped to do its job after all the suggested mods were made (Zoodad, dfuser, and fender sleeve)?
Of the three suggested mods, the fender sleeve appears most radical to me for the reason that it requires actually opening the side of the AIS. Not sure I want to chance buggering up the filter. I'm likely going to choose between Zoodad and dfuser mods, with leaning toward the dfuser mod right now.
Pop, thank you for an excellent description of the situation!!
Old Nov 6, 2007 | 11:35 AM
  #74
SpringerPop
In reality, the fender sleeve mod is likely the one that's really going to solve the problem. It's the only one that actually lets more air into the housing.
If I were doing it, however, I'd likely not cut the hole into the side of the housing with the intent of taking in air from the fender well, as that could be real dusty air at times, but look at some venting holes in the housing in another place. That would allow warmer, under-the-hood air to be drawn in (not really a good thing) instead of cooler "outside" air, but this whole project seems to be full of trade-offs.
The bottom line is that the air, after passing through the AIS filter element, is very clean, and the element, itself, is capable of filtering more-than-enough air to meet our engine's highest demands. Getting enough air AVAILABLE TO that element is the root problem that needs to be solved for the FilterMinder to accurately do its job.
Pop
Old Nov 6, 2007 | 11:53 AM
  #75
dfuser's Avatar
dfuser
Thumbs up
Pop
Well said. I agree!
thedaddycat
Oil & Lubrication
Feb 27, 2008 06:12 AM
Imdok
Oct 11, 2007 01:11 PM
brettwingfield
Sep 16, 2007 09:14 PM
macwilj
Jul 28, 2007 08:26 PM
randy332
Mar 8, 2007 06:47 AM
