Removing column shifter
Old Jun 3, 2007 | 08:52 PM
hwsykes's Avatar
hwsykes
How do you remove the column shifter from the steering column? I need to paint mine.
Thanks!
Old Jun 3, 2007 | 09:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hwsykes
How do you remove the column shifter from the steering column? I need to paint mine.Thanks!
The shift collar flange which holds the lever, or just the shift lever? The wheel must be removed to get at the collar, you will need a steering wheel puller. The lever is held to the flange by two small stepped inserts with springs behind them as original.
Old Jun 4, 2007 | 07:05 AM
hwsykes's Avatar
hwsykes
Yes, just the arm itself. Do you just tap out the inserts?
Old Jun 4, 2007 | 10:22 AM
66 POJ's Avatar
66 POJ
If its the original you have to press those peices together that hold it on that Bill is talking about. Although some aftermarket ones have a pin with groves in that press in, and you'll have to press it out in one peice.
52' fordnut
Dec 10, 2012 07:51 PM
salf100
Oct 17, 2011 11:14 PM
custom cabby
Sep 14, 2009 01:51 PM
