3SPD Shifter removal
Old Oct 17, 2011 | 04:04 PM
salf100's Avatar
salf100
Do you remove the column shifter just by tapping out the single pin at the column? Is there a spring behind it thats going to go flying? And how about removing the black plastic shift ****, tap it off also?
Old Oct 17, 2011 | 05:16 PM
66CustomCab's Avatar
66CustomCab
I can tell you that the black **** slides off. Not sure if there are any springs in there like with my automatic.
Old Oct 17, 2011 | 10:35 PM
Tobys351.9's Avatar
Tobys351.9
shifter handle
Take the pin out and pull the handle straight out.
It has a rubber boot around it inside the shifter collar and can be tight.
This pic is what it looks like.
Old Oct 17, 2011 | 10:41 PM
Tobys351.9's Avatar
Tobys351.9
Entire Column
Here's a diagram of the column, it helped me when I rebuilt mine.
File Type: pdf
Old Oct 17, 2011 | 10:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Tobys351.9
Here's the Ford truck parts catalog diagram of the column, it helped me when I rebuilt mine.
Located here: 1964/72 Ford Truck Parts Catalog / Illustration Section 35, Page 8.
Old Oct 17, 2011 | 10:56 PM
Broomfieldbum's Avatar
Broomfieldbum
That little pin is all there is. I just replaced all of that stuff. I destroyed the **** with a hammer because I wanted to paint the shaft and get a new ****. The pins tap right out no flying objects.
Old Oct 17, 2011 | 11:14 PM
NumberDummy
The **** was sold separately originally and is pressed on. Getting the old **** off can be a real b!tch. Usually it has to be broken off.
If the lever is soaked in boiling water for about 5 minutes, it can 'sometimes' be pulled off with pliers.
shadow_almanza
Apr 8, 2012 11:37 AM
rob8210
May 14, 2008 06:51 AM
460
Oct 28, 2007 08:50 PM
Old Speed
Jun 26, 2005 11:04 AM
