Average Mileage on a 302?
Old Jun 3, 2007 | 05:56 PM
NeXtras's Avatar
NeXtras
I have a 1994 302 Windsor and I just hit 175k... is that a lot of miles for a 302? i love my truck and really dont want to get rid of it... whats the longest some one has seen these run... should i start to worry about the engine? I do all the regular mainenence myself, oil every 3k with 10W-40, puting a new cap and rotor on soon... tranny probably has 75k-100k on it, rebuilt a while ago.
I have paranoia lol soo yeh... just givce me some tips to pro-long the life of my engine.
Old Jun 3, 2007 | 06:24 PM
brown 4x4's Avatar
brown 4x4
Some only run 100K, some 300K. It all depends on the care and use it's had, and a little luck. Mine's doing just fine at 210K other than a couple minor leaks. If it's running strong and healthy now, don't worry about it. I'd probably use 10w30 oil instead; do some reading and decide for yourself though.
Old Jun 3, 2007 | 06:27 PM
Wingman69's Avatar
Wingman69
Well my truck is a 93 f150 with a 302 and it has 225k miles on it. I got it a couple years ago from my uncle when it had about 205k miles on it. I have replaced the wiper motor, the starter, coolant temp sensor, plugs, rotor, and of course oil changes. Just recently I replaced the pcv valve. It of course leaks at the rear main and possibly one other spot. It has just recently started idling rough, so I need to look into that. I was thinking of using some Seafoam on it, but I'm kinda afraid it will clean off what is keeping the truck running.
Old Jun 3, 2007 | 07:12 PM
Dustin1690's Avatar
Dustin1690
Well i have heard people who have had there trucks with the 302 over 300,000 km and still going pretty good im sure the engine will outlast the body unless you live in a rust free area but they rust quick
Old Jun 3, 2007 | 08:39 PM
NeXtras's Avatar
NeXtras
mine seems to be running stron.. its my first vehicle so its hard to tell how other engines run, my dad has a 2003 F150 that i drive but it have a Triton 5.4 so you can't compare the two trucks... The wiper motor i know needs replaceing... $200 lol not cheap tho.. going to get cap and rotor as i stated, thinking of getting new plug wires as well...
Old Jun 3, 2007 | 08:56 PM
shooter05's Avatar
shooter05
Well my 91 has 270,000 miles and it still gets about 14mpg on average. I have the rear main drip but it has always been great.
Old Jun 3, 2007 | 09:10 PM
Wingman69's Avatar
Wingman69
Yours uses the same wiper motor as mine and I got mine @ autozone for $74-25 for core. It was fiarly simple to put in. Autozone has the repair guides online if you register on their site.
Old Jun 3, 2007 | 09:32 PM
88 f150's Avatar
88 f150
If your up to it you may benifit from a new timing chain and gear set. Change the water pump while your there.
Old Jun 3, 2007 | 10:54 PM
McLeod's Avatar
McLeod
Gear ratios can come into play also.
Maintainance aside, a 302 with 200k running 3.55 ratio is going to have less effective wear than the same 302 running 4.56 ratio.
The life span of the deeper geared set up will quite probably be less.
Old Jun 4, 2007 | 07:32 AM
NeXtras's Avatar
NeXtras
ok, so how do you go about changinng the gear ratio... is it simple?
Old Jun 4, 2007 | 08:02 AM
chadc2003's Avatar
chadc2003
within the last year i put 20,000 on my 96 w/ 302 and its got a jegs y pipe and a 2.5 inch exhaust with a 5 speed and 3.55s. i also made my own cold air dealy which i noticed a huge difference in performance when i did that. but anyways mine gets about 13.8 driving around home and about 14-14.5 on the freeway. not to terrible for a 4x4. i got it last febuary with 93,000 on it as of last night it turned 120,350 and the only leak is the rear main but it doesnt lose any oil between changes. i guess i cant complain about it all 210 horsepower...lol
Old Jun 4, 2007 | 02:39 PM
McLeod's Avatar
McLeod
It takes specialized tools and knowledge.
Gear changes come with trade offs.
Old Jun 4, 2007 | 07:08 PM
NeXtras's Avatar
NeXtras
does the 1994 302 have 210hp or 185hp??? wasnt too sure.... i have a catback on it already so it does breathe better. its good to know these engines work for a long time BUILT FORD TOUGH!!!
Old Jun 4, 2007 | 07:12 PM
Dustin1690's Avatar
Dustin1690
Yeah im confused i have a 93 f150 and i was told it the 351W has 210 hp??..
Old Jun 4, 2007 | 08:28 PM
Wingman69's Avatar
Wingman69
For 1993 models, this is what i have.
