Sponsored by: Real Truck
Leaning
Old Jun 6, 2007 | 04:33 PM
hotroddsl's Avatar
hotroddsl
I like superlift & have also used rancho but you can also have those factory springs re-arched & keep the factory ride softness as well as keeping your wallet a little more "portly" but if it was me? 6" superlift
Old Jun 6, 2007 | 06:28 PM
Wolverine69's Avatar
Wolverine69
Do you have an equal number of leaf springs on each side?
Have you checked to see if you have an equal number of leaf springs on each side of the truck?
I didn't notice at first, but when I purchased my 2000 F450 last fall it had some extra leaf springs installed on the passenger side of the rear axle. Apparently a previous owner had installed them to handle the weight of something, possibly a bed mounted crane, being mounted on the passenger side of the previous bed. I didn't notice any of this until I took the truck to get a new flat bed installed and they pointed out that the truck leaned towards the driver's side and they suggested that it was possibly something like a crane that had been mounted previously.
Old Jun 7, 2007 | 05:28 AM
Lovin7.3's Avatar
Lovin7.3
Yeah that was the first thing I had done was count the leaf springs. They all have the same on each side.
Old Jun 7, 2007 | 10:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
One way you can pinpoint the problem are is to go over a large, wide speed bump at a low speed. Normal suspension will flex equally, but if you have a bad shock like I described earlier that end of the truck will feel like it is trying to roll away from the bad corner. If both front and back feel OK when going over a large wide speed bump, your shocks are probably OK.
Old Jun 7, 2007 | 03:15 PM
Lovin7.3's Avatar
Lovin7.3
Alright ill give it a shot thanks
slovride
Apr 2, 2013 12:41 PM
clego
18
Dec 21, 2011 07:54 AM
jeffp_032056
Escape & Escape Hybrid
Mar 15, 2009 08:17 PM
hazeljen
May 24, 2005 09:16 PM
ealopez
1997 - 2003 F150
Jan 17, 2005 03:39 PM
