Engine coolant change procedure
Old Jun 1, 2007 | 09:30 PM
mjlevi's Avatar
mjlevi
Can anyone please describe the step by step details to change and/or flush the cooling system on the 6.0l, (and I mean, step by step)!! and maybe they can be placed in the Tech Folder...as all the other fluid and filter change methods are there except the cooling system...
Old Jun 1, 2007 | 10:08 PM
blackhat620's Avatar
blackhat620
You realize this only has to be done at 100K miles?
To drain a cooling system you want to open the petcock on the radiator and drain the coolant into a container to properly dispose of it. Then close the petcock and refill the system with water, run the motor to circulate the water and then drain the system again. Remove the radiator hoses and heater hoses and drain them. Install all the hoses, close the petcock on the radiator and then fill with a 50/50 mix of Motorcraft Premium Gold Coolant WSS-M97B51–A1 and Distilled water. Start the engine let the truck warm up and add more coolant & distilled water to bring up to the correct level. Check the system for leaks and you should be good to go.
Hope this helps
LRSTony
Mar 19, 2012 07:53 PM
wongs83
Apr 11, 2011 06:14 PM
matt57
2009 - 2014 F150
Apr 14, 2009 07:12 AM
wranger
1983 - 2012 Ranger & B-Series
Nov 11, 2003 02:54 PM
MickeyP
Jul 15, 2002 12:09 PM
