2002 Expedition Rear AC
Old Jun 1, 2007 | 06:56 AM
chaneyb's Avatar
chaneyb
Trying understand a problem with the rear auxiliary unit. My 2002 Expedition has electronic climate control and front AC & Heat works fine - blows both cold air and hot air. The rear unit only provides "room temp" air when the aux temp control is placed all the way on cool. If the aux temp control is moved to "warm" the unit does blow very heated air so seems like the blend door is moving. Appreciate any help...
Old Jun 3, 2007 | 05:43 PM
ReAX's Avatar
ReAX
Sounds like the rear condensor/evaporator/whatever is in the box in the rear is not getting cooled. I can't imagine you have completely independent systems for front and rear, so I would assume you have one compressor that feeds both whatevers. I'd suspect a blockage.
Old Jun 4, 2007 | 12:18 AM
bustech81's Avatar
bustech81
I belive that you are correct in thinking a blend door. hot air from a convector coil will kill any attempt to cool return air.
Old Aug 20, 2007 | 12:17 AM
genek's Avatar
genek
Hi,
I have the same problem. So by replacing the temperature blend door actuator the problem will be solve, or is a different issue?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 20, 2007 | 01:00 PM
ReAX's Avatar
ReAX
Sometimes, but sometimes, you just have a piece of debris jambing the door open.
Old Aug 20, 2007 | 01:26 PM
genek's Avatar
genek
Thanks for the reply.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
So I should take off the temperature door actuator and check the door?<o></o>
One more thing the evaporator core on the climate control housing is cold, that’s a good thing, right?<o></o>
Old Aug 20, 2007 | 01:35 PM
ReAX's Avatar
ReAX
Yes and yes
Old Aug 20, 2007 | 09:53 PM
genek's Avatar
genek
I removed the temperature blend door actuator and is working. I have done this with out removing rear quarter trim panel. To get to the door I have to remove the quarter panel, right? Any tricks there?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
One more thing the expedition is 03 Ed
vreynaud
Jul 17, 2019 05:57 PM
aj270
Jun 3, 2011 01:44 AM
oem78
Sep 6, 2009 10:24 PM
ugotkern
Dec 17, 2005 03:19 PM
chaneyb
Jun 21, 2005 03:42 PM
