U-joints
Old Jun 1, 2007 | 12:55 AM
boatcop1's Avatar
boatcop1
U-joints
what are the symptoms of U-joints begining to go bad? On occasion when I accelerate harder than normal I can feel a slight vibe/grind through the gas pedal and floor, it is very slight but it is there! You guys know the feeling! any ideas?
Old Jun 1, 2007 | 04:02 PM
Freak4Ford's Avatar
Freak4Ford
I had the same problem with my Expedition. It would shimmy and vibrate something awful. Sometimes. It was not there always but it was a real pain. Turns out it was the U joints. Excessive vibrating gone.
Old Jun 3, 2007 | 11:58 AM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
boatcop, that is almost the EXACT symptom of a u-joint starting to go bad.
You may have to remove the driveshaft and work each joint separately to be 100% sure though... sometimes they can freeze up but still have no play. Other times you have to "unload" the joint to be able to find the play.
Good luck.
Old Jun 4, 2007 | 03:09 PM
boatcop1's Avatar
boatcop1
Good luck.
Thank you, I'll be putting it on the lift tommmorrow so I'll chech this.
redsuperduty
Feb 6, 2026 05:07 PM
dantsg
1997 - 2003 F150
Apr 12, 2008 12:21 AM
tps93ranger
1983 - 2012 Ranger & B-Series
Dec 30, 2006 10:18 AM
jlande
38
Sep 4, 2006 09:40 AM
