fuel pump ?
Old Jun 2, 2007 | 07:42 AM
F350_Hauler's Avatar
F350_Hauler
Thumbs up Easy fix for the IPR o-rings
Take off the little tin nut. Slide the solenoid off the post. Put special socket onto the IPR and loosen it and take it out. Get it in your hand, replace th two o-rings and put it back in. Slide the solenoid back on and snug up the tin nut really good but don't break it. With the socket in hand you can do it in less than 10 minutes even if you drop the tin nut and fish it out with a magnet and drop the little rubber seal for the electric plug hookup and fish it out with a little piece of wire.
The special tool is a 1/2" drive deep 1 1/8"(I think) socket with a little piece of metal welded out of the side of it so it looks like a chainsaw wrench. It's easier to not put the little piece of metal at the end like a chainsaw wrench. Put the piece of metal in the middle and it ends up being easier to use. The other option is to try to find an old socket with a six-sided end that you can put a wrench on. Some of the tool companiea used to put a six-sided bolt-like head on the end of the socket that you could put a wrench on. It works great because you can just get the wrench down in there without taking apart the fuel filter canister or anything else major.
Old Jun 2, 2007 | 11:17 AM
bigbadwolfe's Avatar
bigbadwolfe
will a bad ipr cause white smoke out the tail pipe ?
Old Jun 2, 2007 | 05:45 PM
tjbeggs's Avatar
tjbeggs
It could cause white smoke (low high pressure oil pressure could cause poor atomization which would cause white smoke white smoke). do you have anyway to hook a scanner to it to watch the HPOP?
Old Jun 2, 2007 | 07:02 PM
bigbadwolfe
not untill monday my friend at the shop has a snap on scanner will this do it
Old Jun 2, 2007 | 07:14 PM
tjbeggs's Avatar
tjbeggs
yes the snap on will. you need to watch ICP pressure while cranking and running. To start you need atleast 470 psi. let me know what you see idling and running down the road and at wide open throttle. With the starting issue hot you more than likely need atleast IPR o-rings.
66ca
52
Apr 15, 2012 04:43 PM
f250d4x4
Jan 6, 2012 08:18 PM
dffdixie
1983 - 2012 Ranger & B-Series
19
Sep 11, 2009 11:02 AM
Duksrule
Jul 1, 2009 10:03 AM
Wodman
Aug 15, 2003 03:45 PM
