Dash gauge problem
Old May 30, 2007 | 07:48 PM
RubberDuck's Avatar
RubberDuck
Dash gauge problem
Guys, my brother in law's 99 has a problem. The truck will start, but no gauges register. When you start it, no wait to start light. Only the battery light and seatbelt light. All the gauges are dead. Also the the throttle is working speraticly. He did have problems with the od wires and had to repair them some years ago. We think one might have shorted. What would that take out? Thanks for your help.
Old May 31, 2007 | 06:39 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Sounds like he fried something. Does the horn and wipers and windows/doorlocks etc. all still work?
Old May 31, 2007 | 06:41 PM
RubberDuck's Avatar
RubberDuck
Thanks for the reply cookie. We found it, it was a fuse. He checked them, he just missed it. Problem solved, hopefully. We think the wires he fixed just popped the fuse, so we went back in and fixed them right. Thanks.
Old May 31, 2007 | 08:57 PM
elw459's Avatar
elw459
I have the same problem, but my fuse blows about once a week. I traced it out on a wiring diagram and that fuse is tied into the throttle pedal, overdrive button and a solenoid in the trans. Sometime the fuse blows at start up and sometime when shifted into drive. What wires did you find chaffed and where? thanks.
Old May 31, 2007 | 09:40 PM
RubberDuck's Avatar
RubberDuck
elw, they are really easy to get to. pull the bottom dash cover below the column. Then pull the bottom and top column covers. There you will see the (I believe) three wires coming out of the shifter handle. You can unplug that harness just before it disappears under the gauge cluster very easily. If you find a chaifed wire and from the sounds of it you will. Take a small hammer and punch and knock out the roll pin holding the shifter in. Once the knock the roll pin out, the shifter just comes out. Now you can work on it in the shop or on a bench. I don't recall what color the wires were, but I believe there are only three that come out of the shifter. I really was an extremely easy fix. He said "column", and I said "oh hell!!!". But it was as cut and dry as I described. I hope that helps.
Old Jun 1, 2007 | 09:13 PM
elw459's Avatar
elw459
Thanks for the info, I found he OD wire chafed and repaired it, took about 20 min.
Old Jun 2, 2007 | 07:10 AM
RubberDuck's Avatar
RubberDuck
Glad I could help.
Old Nov 17, 2007 | 02:29 PM
bnelson's Avatar
bnelson
Hello,
A blown 10A fuse (#19- PCM, Control Panel) caused my F-250, 2000 7.3L, Diesel to simply stop. The truck would start and simply idle when the accelerator was pressed. No throttle response, and no panel display besides battery and airbag. My main indication that it was electrical was that I had just driven the vehicle home ran in to grab the kids for a pizza party, and then the lack of response.
This post is for information only in the hope that someone else will not end up paying for towning, diagnostics, and loss of vehicle for several days (Ford dealer is not open on the weekend, and was happy to have my truck towed there and sit until Monday).
Cheers, -bn-
F-250 2000 7.3L
Stock
1979camperspecial
Jul 22, 2014 12:08 PM
weldworks54
Sep 15, 2011 11:23 AM
Resting River Ranch
Jun 11, 2009 06:57 AM
dbrad4d
Dec 21, 2006 09:52 AM
T_Moss
Electrical Systems/Wiring
Oct 26, 2003 07:59 PM
