Trans overheat
Old Sep 14, 2011 | 07:44 PM
weldworks54's Avatar
weldworks54
Trans overheat
Driving home today I looked down at the gauges trans temp gauge was pegged out, check gauge light was on and tow light was flashing pulled over checked oil it was full so I limped it home went out an hour later started the truck no lights on gauge showed normal drove about a mile light came on, gauge pegged out, and tow light was flashing trans cooler is warm but not hot " you can hold your hand on it" I have done a search and found that the gauge sensors are a common problem. And that the external filter could be stopping up my question is : is it that common of a problem that I should go ahead and change it while I have the trans pan off changing the oil and filters?
Old Sep 14, 2011 | 07:49 PM
69cj's Avatar
69cj
More than likely the tft sensor in the tranny. I assume also that the tranny is serviced per manual with only the specified fluid and new ext. filter.
Old Sep 14, 2011 | 07:57 PM
BLADE35's Avatar
BLADE35
mine does this to especialy during warm up when it gets to normal operating temp it calms down
03 doesnt go into limp mode though and doesnt do it often
Old Sep 14, 2011 | 08:11 PM
weldworks54
Don't really know about the servicing I just bought the truck "2 weeks ago" I was planning on servicing the transmission and differencals this week end just so I know they have been changed the fluid doesn't look real bad but it's alittle orange looking is the reason I was going ahead with the oil change while I was driving it with the light off before it came back on it was shifted normally till it went in to tow/ haul " limp mode"
Old Sep 14, 2011 | 08:35 PM
weldworks54
I've been digging around without any luck is there a link with a picture of this sensor? And should I still use a motorcraft filter or can you use an aftermarket ?
Old Sep 14, 2011 | 10:13 PM
Unrealo4's Avatar
Unrealo4
Hey weldworks I slapped this little write-up together a couple months back. Its pretty easy, I just thought it was much worse then what it was. So I made this to help others realize how easy it is. I was hopeing someone would put this in the tech folder where it could help others.
https://www.ford-trucks.com/forums/1...l#post10075886
Old Sep 15, 2011 | 06:28 AM
weldworks54
Unrealo4 thanks alot those pics really help me! I am mechanically incline but don't always know where or what a part looks like so the pictures really help thanks again
Old Sep 15, 2011 | 11:23 AM
weldworks54
I Got the sensor order from local ford dealer this morning of coarse they don't stock it and want be here till tommorrow but I got lucky and it the $15.00 dollar one and not the $450.00 dollar one so that may leave enough in the kiddie for a new scangauge ; )
s_herod
Nov 14, 2024 03:39 PM
Tuck45311
Apr 1, 2017 09:52 PM
Spool&Go
Aug 8, 2016 12:35 PM
Gwilkrrs
6.4L Power Stroke Diesel
Jul 13, 2016 05:14 AM
zave
Jan 19, 2005 12:40 PM
