1966 - 1977 Early Broncos
bronco lift question
Old Jan 18, 2002 | 06:34 PM
69BRONCO's Avatar
69BRONCO
I want to install a dual shock
suspension lift on my 69 bronco. I halfway picked this one out at james duff. What else will i need to get it right. Will i need new longer brake lins? will i need longer driveshafts? will i need the pitman arm? What other suspension lifts are good and where can i check them out at. Thanks.
jake
http://wwwhttp://www.jamesduff.com/eb/suspension.html.
Old Jan 25, 2002 | 03:59 PM
jhavins's Avatar
jhavins
Jake, The brake lines vary. You might have to if you do not have enough "slack". The driveshaft, well...No, you wont have to replace, unless you are lifting this thing to the sky, however you must change seals and everything but that is very cheap. The pitman arm you must replave if you are lifting more than 2.5 inches. It would cause to much stress on your ball joints. Hope this helps.
Jake (my name also)
Old Apr 23, 2002 | 01:14 AM
twister12345's Avatar
twister12345
Post bronco lift question
look on wildhorses4x4.com they have good products and they have 12 diferent lift systems available.
jeff
Old Apr 23, 2002 | 01:21 AM
twister12345
Nev3rl1ft89
1978 - 1996 Big Bronco
Nov 4, 2010 10:38 PM
95Bronco
Aftermarket Products
Mar 16, 2006 04:17 PM
jim's78
Jul 6, 2004 10:49 PM
69BRONCO
Nov 25, 2001 07:00 PM
nickc84
Bronco II
Aug 20, 2001 10:42 PM
