Aftermarket Products
Sponsored by: Worksport
Help with a lift
Old Feb 28, 2006 | 06:48 PM
95Bronco's Avatar
95Bronco
Help with a lift
I am looking into buying a 6" suspension lift for my 95 ford bronco and i need to know what other parts i will need if i just buy the kit not the system
Old Mar 15, 2006 | 06:15 PM
ruffnready's Avatar
ruffnready
im not sure what you mean by 'kit' or 'system'... the kit i bought and all that my buddies purchased came with everything you need (drop down brackets, rear blocks or leafs radius arm drop down, brackets, coils the whole deal) i wouldnt think it would be feasible to buy the lift piece by piece so i would look for a whole kit that has everything to at least do the front(everything minus leafs or blocks) you could always do the rear from your local parts store
Old Mar 16, 2006 | 10:19 AM
i1dery's Avatar
i1dery
I was whatching a show the other day and i wanna say that a Kit comes with everything you need to lift your truck 4" 6" 8" whatever you want. And a system
comes with all the same but allows you to up grade later when you feel the need to,
And don't qoute me but thats what i understood it to be.
Old Mar 16, 2006 | 12:38 PM
wyoguy's Avatar
wyoguy
Kit is new front springs of helpers and things needed to lift front, but comes with blocks to lift rear
System comes with everything to lift front, but comes with new springs instead of blocks to lift rear.
Old Mar 16, 2006 | 12:46 PM
NH-Hottie's Avatar
NH-Hottie
I was pricing lifts for my Bronco, 4 years ago. From what I remember, the difference between a kit and a system, is how complete you want it and the price. A kit, has the bare essentials, where as the system has alot more that makes it pricier. They also come in two different classes. A class I has blocks and the Class II has the heavy duty leaf springs. If you were to get a Class II 6" system, you will get the drop pitman arm, springs, coils, shocks, bump stops, rear u-bolt kit, extended radius arms and sometimes the extended stainless brake lines. There are also some misc. small stuff that I can't remember. I ended up getting all of the above, minus the radius arms and stainless lines, which brought the price down 400 bucks. Even though I am happy with what I got, I think I would put the extra 400 in for the complete system, if I had to do it again.
Old Mar 16, 2006 | 04:17 PM
79 Trailer Special's Avatar
79 Trailer Special
Keep in mind if you go with a 6" lift you may have to go with longer driveshafts. It gets real close with the 6" kit, some get away with it but if you plan on any hard wheeling it will be a must.
Coop01
1978 - 1996 Big Bronco
18
Jun 24, 2011 02:17 AM
bob1987f
Offroad & 4x4
Aug 1, 2007 06:58 AM
fordinmudd
Jul 23, 2006 03:27 PM
offroadguy56
Oct 10, 2003 07:23 PM
windrider
Oct 21, 2000 04:51 PM
