1966 - 1977 Early Broncos
disc brake conversion question
Old Jan 15, 2002 | 10:05 PM
spartamouse1's Avatar
spartamouse1
has anyone converted to disc brakes and not changed to power brakes? will it still stop ok or will it be harder to stop? trying to decide how much effort this is going to take and if it will be worth it.
Old Jan 16, 2002 | 09:10 PM
alpo23's Avatar
alpo23
I have converted to the Disc brake kit that Wild Horses sells. I don't have a power booster. It is only SLIGHTLY heavier than the Drum set-up. And I mean only slightly. I find they stop fine and would never go with a power booster 'cause I don't want to worry about loosing the brakes if the the engine cuts out on a hill. The bronco doesn't weigh enough for me to need a booster.
Good luck,
Eric
Old Jan 17, 2002 | 01:53 PM
spartamouse1
thanks for the response. i never thought about loosing brakes if the motor quit, good idea. i was more along the line of not putting anything more in the engine compartment to have to work around.
parts man
Old Apr 23, 2002 | 01:21 AM
twister12345's Avatar
twister12345
just make sure you get the valve meitrin because the disks take mor preasure to stop
Old Apr 23, 2002 | 10:17 AM
Drewguy007's Avatar
Drewguy007
