Bolt Patterns
Old May 29, 2007 | 07:51 AM
Red_EB_Bronco's Avatar
Red_EB_Bronco
Bolt Patterns
Wow its been a long time since I last posted anything and I'm really surpsrised that I remembered the user name and password anyway.
I'm looking for some info on the bolt patterns of 85-00 F-250s, can anyone tell me when they changed and to what?
Thanks, Charlie
Old May 29, 2007 | 08:14 AM
Pocket's Avatar
Pocket
The bolt pattern changed in 99 with the introduction of the Superduties. It's currently 8 x 170mm. The older trucks are 8 x 6.5.
Also the offset changed in 05, so even though the newer rims can bolt up to a 99-04 Superduty, they will cause tire rub issues. Wheels from a 99 and up will not fit any year prior to 99.
Old May 29, 2007 | 12:23 PM
Red_EB_Bronco
Thanks, thats just what I needed!
How about this question, I need to sell some rims off of a 99superduty and 2005dually. Where is the proper section for that and are there any fees? please point me in the right direction!
--Charlie
Old May 29, 2007 | 05:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Pocket, also in 2005 they changed the bolt pattern on the 250s and 350s. They are 8x200, not 8x170. You can't put a 05 or newer wheel on a 99-04 truck.
To sell stuff, look at the very top of this page, in the silver toolbar going across. Fourth from the right is Classifeds. Click on that and youre on your way.
Old May 29, 2007 | 06:38 PM
Pocket's Avatar
Pocket
You might want to check again. It's still 8x170 in '05 and up models. There are folks who have bolted up a wheel from a newer Superduty onto a 99-04 model, but had major issues with the tires rubbing up against the leafs. Some have used wheel spacers to correct the issue, but spacers on these trucks are definately not recommended, especially if you tow.
Someone posted a pic once with 20's from an '05 that he installed on an '02 or '03 model. I'll be buggered if I can find it now, but it looked goofy with the wheels tucked in so far under the wheelwell.
Old May 29, 2007 | 09:47 PM
DaveWilliams's Avatar
DaveWilliams
Super single rear tire
Has anyone ever seen a "Supersingle" wheel and tire on one of our duallys? I have seen them on big rigs as a substitue for the duals but was wondering of anyone has tried it on a superduty?
Old May 29, 2007 | 09:50 PM
John311t's Avatar
John311t
I seen it on a modified cummins with some slicks on the back, looked really nice. But the truck was also lowered, shaved handles, and had twin turbos. It was a nice truck, i loved the SRW under the dually fenders.
Old May 29, 2007 | 10:18 PM
rebelchevy02's Avatar
rebelchevy02
Heres a little bit on the 08 superdutys, right off the ford site...
Number of studs 8 (F-250/F-350); 10 (F-450)
Bolt-circle diameter 6.7” (170-mm) SRW; 7.87” (200-mm) F-350 DRW; 8.85” (225-mm) F-450
I looked at the 07 model, but they dont list specs on wheels for them anymore. Looks like DRW gets the 200mm spacing, atleast for 08.
