Submersible pump problem
Old May 28, 2007 | 07:37 PM
scole250's Avatar
scole250
I have a well with a 4" SS Grundfos 5hp pump used for irrigation. It's set up to pump 30gpm, but I was using it to run a single 5-10gpm sprinkler. It quit. Yeah, I know. It's not supposed to cycle, but it was. It has a control box. If I press then reset button, the control box hums for 10 seconds or so, then clicks off. Does this sound like a control box (capacitor or relay) problem or have I fried the pump? I have a troubleshooting guide, but I don't like messing with 30amp 220v stuff. I'm trying to get an electrician over here ASAP. Just looking for advice.
Old May 28, 2007 | 10:14 PM
King Triton's Avatar
King Triton
It might just be a capacitor problem,thats what the cap is for,during start-up the motor draws more amps than what the line supplies and the cap gives a surge of electricity to help get it going.
Old May 29, 2007 | 12:15 AM
wlihntr's Avatar
wlihntr
sounds like you may have locked up the pump. i have seen locked up bildge pumps do the same thing...it takes a few seconds to build up enough current to kick the breaker.
Old May 29, 2007 | 12:42 PM
scole250's Avatar
scole250
WOOHOO! A friend help me test the control box and I only had to replace a $23 run capacitor.
Old May 29, 2007 | 04:58 PM
ckal704's Avatar
ckal704
Gotta love it when it is not a "worst-case" scenario!!
Old May 29, 2007 | 05:21 PM
Ford_Six's Avatar
Ford_Six
You probably should set it up to run constantly, either running additional sprinklers or just dumping the water back down the well (if it's an open well).
Old May 29, 2007 | 07:44 PM
scole250's Avatar
scole250
I never knew they existed until recently while I was researching my pump problem, but they make CSV (cycle stop valves) that keep back pressure (false head) on the pump and keep them running instead of cycling. There's different types. I'm going to have one put in that has a max flow rate of 50gpm and min of 2gpm.
Old May 29, 2007 | 08:35 PM
lenny1carl's Avatar
lenny1carl
and keep a spare start capacitor around...... you never know. i used to keep 10 in my work truck when i was on the road.
i had 300 coustomers around the Adirondacks.
seville009
15
Jun 6, 2018 01:29 PM
bashby
Jan 8, 2014 01:28 PM
omni
22
Sep 21, 2007 01:26 AM
Bruker
Jul 23, 2007 08:14 AM
