Lawn Mower question
Old May 28, 2007 | 06:10 PM
ranger rules's Avatar
ranger rules
Lawn Mower question
How often do you change the oil in your lawnmower?
Old May 28, 2007 | 06:21 PM
Patatoe1's Avatar
Patatoe1
Once a week, but I use it for work and am cutting two full days. So usually after 12-15 hours.
Old May 28, 2007 | 07:15 PM
jake00's Avatar
jake00
every season of use
Old May 28, 2007 | 07:16 PM
magnum300's Avatar
magnum300
Usually just in the spring but i do not water so not much cutting in July and August
Old May 28, 2007 | 07:38 PM
lenny1carl's Avatar
lenny1carl
2x's per season. same with the snowblower. and every tank of gas in both get a splash of STA-BIL
Old May 28, 2007 | 07:42 PM
fordtruckman's Avatar
fordtruckman
every season also
Old May 28, 2007 | 09:07 PM
surewhynot's Avatar
surewhynot
Once a season, and I second the splash of stabil in the gas.
Old May 28, 2007 | 11:55 PM
70blue's Avatar
70blue
Once a year and it usually looks fairly clean when I drain it. I will probably change it twice this year. It is very dry so I am not using it as much but I end up stirring up alot of dust because of the dryness. Already had to clean air filter twice. I usually only have to clean air filter once per year.
Old May 29, 2007 | 12:32 AM
jimbo beam's Avatar
jimbo beam
I change it every spring before the first fireup, i pick it up in a kit with a new plug and air filter. I use stabil but only when its gonna sit with gas in it for a while.
Old May 29, 2007 | 12:34 AM
wrobo23's Avatar
wrobo23
once a yr i change oil and filter. every now and then sharpen blade. sta only b4 winter.
Old May 29, 2007 | 01:43 AM
jimbeamalki's Avatar
jimbeamalki
Manual says every 25-30 hours. Takes and hour with wife on the rider and me pushing the trim. Started logging them on the calender in the garage last year just for fun, and we mowed 30 times. I've always changed the oil, spark-plug, cleaned filters and sharpened blades once a year at the start of the season before we start mowing.
Old May 29, 2007 | 05:56 AM
Hawk1953's Avatar
Hawk1953
At the end of the season so I have a fresh clean engine to start with the next season, and no sludge settling down over the winter. And yes a shot of Sta-bil in the fuel over the winter.
Old May 29, 2007 | 06:31 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Oil changed in everything at the start of the (appropriate) season.
If I have cut grass more than usual (like cutting my parent's lawn and my daughter's - which is now the usual routine) I'll change the oil mid-season.
Lawnmower blades are sharpened at the beginning and in the middle of the season. (Sharp blades are 'better' for the grass.)
Sta-Bil goes into the containers that I put gasoline in. (Year round.)
I have experienced gas turning to 'varnish'. I put the dosage for long-term storage in each 5 gallon container.
Old May 29, 2007 | 07:21 AM
Nitramjr's Avatar
Nitramjr
Your supposed to change the oil in these things?
I do mine every other year or so if I remember. Or if it looks dirty or is low I change it. My equipment usually rusts away before the motor goes so I don't obsess on oil changes on the small stuff like I do on my cars and trucks.
I borrowed a buddy's tiller over the weekend. It was running rough so I adjusted the carb and changed the oil in it - the oil was as black as tar. He said in the 25+ years he has been using it the oil had never been changed. Still, it starts on the first pull every time. They don't make Craftsman stuff like they used to.
Old May 29, 2007 | 09:00 AM
wizzard351's Avatar
wizzard351
a bought a alcheapo murry rider witha 12.5hp briggs 3years ago still got the briggs oil and origanal sp plug.ive changed the blades 5-6 times due to bending them on my ol texas lawn.i probably wont change the oil either cuzz the trans is about junk so why waist the $ on oil ill probably have to get a new one next year unless i can find a new trans in the junkyard.what bites is this thing still looks like a brandspanking new one yet and its about toast
