Conical Filter
Old May 28, 2007 | 06:10 PM
Wynn96's Avatar
Wynn96
Conical Filter
Are there any benefits of installing an aftermarket cone type filter?
Old May 28, 2007 | 06:15 PM
srercrcr's Avatar
srercrcr
The benefit is for the company taking your money.
Old May 28, 2007 | 06:16 PM
Wynn96's Avatar
Wynn96
No throttle response or anything?
Old May 29, 2007 | 10:41 AM
BigBlue88's Avatar
BigBlue88
Not hardly. Your best bet for cheap power is replacing your restrictive exhaust, including the converter. The EFI intake flows well enough. Some people mod the air box for better flow, but the factory filter is more than adequate for these low-RPM tractor motors.
Old May 29, 2007 | 03:30 PM
Wynn96's Avatar
Wynn96
Yeah I got the exhaust worked over pretty well, what else can be done cheaply?
Old May 29, 2007 | 05:13 PM
BigBlue88's Avatar
BigBlue88
Well...other things can be done for a few hundred, but they're not simple anymore.
On an EFI motor, most anything else you're going to do will require an adjustable fuel pressure regulator & larger OEM-style (14lb or 19lb) injectors. The OBD1 computer can't compensate for airflow mods, so you have to install a regulator you can play with. Then you can go to the highly highly Crane 260 dual pattern cam- $140 or so, and a new set of lifters. For a poor mans cam, get the larger ratio (1.6 or 1.7) BBC Chevy rockers and just bolt 'em on for more lift. That's $30 plus gaskets (but don't combine with the cam!).
Bohen
6.7L Power Stroke Diesel
Feb 24, 2017 03:18 PM
TerranE
21
Jan 3, 2017 08:43 AM
1buckeyefan
Mar 29, 2011 11:17 AM
Scratcher
Jun 8, 2010 09:50 AM
Monsta
Modular V10 (6.8l)
Mar 22, 2002 03:06 PM
