Modular V10 (6.8l)
K & N air filter
Old Mar 19, 2002 | 11:55 AM
Monsta's Avatar
Monsta
Sit. Stay.
K & N air filter
Old Mar 21, 2002 | 10:25 PM
grmpfrog2's Avatar
grmpfrog2
K & N air filter
Does anyone have any info about installing the K & N air filters over & above the obvious. i.e. , on my '91 460 the dealers shop forman suggested I remove the baffels on the filter to increase air flow. I did that & did notice an increase in power towing my 32' 5th wheel. The air box on this new '02 V-10 is considerable larger but havent had it apart yet. Anyone? Thnx
Old Mar 22, 2002 | 12:56 AM
NoMo's Avatar
NoMo
K & N air filter
Not sure what you are asking... the V10 and 5.4L engines use a cone-shaped filter. It's a simple swap.
As far as I can tell, there are no baffles anywhere in the air intake plumbing. There is, however, a fiberglass "wall" (radiator support panel) in front of the airbox snorkel. You can cut a hole in this panel so that air can be "forced" into the filter. The effectiveness of this mod has never been proven though.
Old Mar 22, 2002 | 02:21 PM
MKJRH 00's Avatar
MKJRH 00
K & N air filter
NoMo:
I drilled several holes in the fiberglass support piece, then decided that it would create a real water intake problem and taped them up. Have you heard of water issues on this mod?
Old Mar 22, 2002 | 03:06 PM
NoMo's Avatar
NoMo
K & N air filter
I've done this to my trucks (previous F250 too) and have never had a problem with water injestion. Unless the truck is smacked with a huge wave of water, I don't see how the opening could be a problem. Not only would a water droplet have to be traveling horizontally to enter the air snorkel, but it would have to go UP to get into the filter housing.
