Turbo intercooler hose
Old Oct 20, 2007 | 10:42 PM
bigdog13's Avatar
bigdog13
My Hose Of The Turbo Also Keeps Blowing Off...my Truck Just Has Mbrp Exh And Know Cat. Every Thing Else Is Stock...already Replace The One Time And Know Its Happing Agin.. I Have Seen On Big Truck Having Cables Hooked On Tube And On Turbo And On Air Cooler... Any On Else Seen This? Thanks Craig
Old Oct 21, 2007 | 02:24 AM
blackhat620's Avatar
blackhat620
bigdog13,
May have turbo vanes that are sticking causing an overboost situation, may want to take it in and have it checked out.
Old Oct 21, 2007 | 09:26 AM
bigdog13's Avatar
bigdog13
The Boost Gauge Don`t Go Over 27-28 Psi Of Boost. I Changed The Hose Before When This Happed To Me It Popped Off Couple Time With In A Couple Mile... And It Was Fine For About A Year. Now It Popped Of 2 Times Last Night On Me...
Old Oct 22, 2007 | 03:02 PM
powerstroked162's Avatar
powerstroked162
Get you some gorilla glue and a pipe expander. Should take care of the issue all together
Cowboy Steve
Old Oct 22, 2007 | 03:57 PM
50jd60's Avatar
50jd60
When I had my 03 dealer changed turbo on it thats when it started blowing off, about a 1/2 dozen times, went to another dealer and they cleaned it and put back on, OK after that, but the mechanic told me it was on backwards, they will go on either way but only 1 way right.
Old Oct 22, 2007 | 04:10 PM
powerstroked162
that what was on backwards? I think your turbo vanes are stickin like Blackhat said
Cowboy Steve
Old Oct 22, 2007 | 09:58 PM
bigdog13's Avatar
bigdog13
[QUOTE=powerstroked162]that what was on backwards? I think your turbo vanes are stickin like Blackhat said
IF THE VANES WHERE STICKIN I WOULD THING MY BOOST GAUGE WOULD GO HIGHER THEN 28 PSI... 28PSI IS WHAT IT ALWAY WAS WHEN I INSTALLED THE GAUGES.
Old Oct 22, 2007 | 10:16 PM
conger's Avatar
conger
Originally Posted by kochennv
I was on the freeway and all of a sudden the intercooler hose popped off right at the turbo any clue on what would do this.
2004 FORD F250 XLS 6.0 Diesel
Thanks Nick
Check the tech folder in 6.0. There's a TSB on that hose and clamps. Mine did the same thing last summer. The replacement parts are under your diesel warranty. The hose with the orange liner won't come off.
Old Oct 23, 2007 | 08:34 AM
50jd60's Avatar
50jd60
Cowboy Steve
__________________
HOLAAAAAAAAAAAAAA!!!!!!!!
BRAAAPPP YA LATER!!!!!!
Northwest Diesel Performance Specialists
Got Boost?
Just to set it straight, blue hose from turbo was backwards, it will go on 2 ways, right way and wrong way, the other mechanic had it on wrong. As far as vanes sticking, why didn't it blow off after it was changed and why did this happen after the turbo was changed. This was on an early 03. that Ford bought back after 2 years of nothing but grief.
BSF350
1997 - 2003 F150
Apr 29, 2016 09:37 PM
BSF350
Apr 29, 2016 06:59 AM
Thor'sHammer
May 9, 2015 04:50 PM
Ford F834
Apr 7, 2012 06:32 AM
conger
Jun 23, 2007 08:47 PM
