Pressure Test Intercooler
Old Apr 27, 2016 | 08:56 PM
BSF350's Avatar
BSF350
I have a leak in my inter-cooler system. I have replaced all the hoses. Is there a reason I should not pressure test the system with 20psi?
2001 F350 7.3 turbo
Old Apr 27, 2016 | 11:00 PM
z31freakify's Avatar
z31freakify
Always do it AFTER the ccv, if not your engine will turn into a fun fountain.
Old Apr 28, 2016 | 01:14 PM
Gatordog's Avatar
Gatordog
Look for any oily spots. You can remove it and have a radiator shop tank it
Old Apr 28, 2016 | 03:29 PM
white Buffalo's Avatar
white Buffalo
Like suggested, remove the air intake so you don't send pressure down the Crank Case Vent tube - or remove the CCV hose (connected to the drivers side valve cover dog house) from the bottom of the air intake and plug it up.
What makes you think you have a leak in the intercooler?
It's pretty simple to remove and doesn't take much time if you want to remove it to pressure test it alone.
Old Apr 29, 2016 | 06:59 AM
BSF350's Avatar
BSF350
Thanks for the help. I will plug the CCV.
jessev1978
Feb 11, 2019 08:35 PM
BSF350
1997 - 2003 F150
Apr 29, 2016 09:37 PM
tjustice
Jul 19, 2012 04:44 AM
Bird Dog
Jul 14, 2007 10:46 PM
Lucky Star
Jul 15, 2006 07:32 PM
