Sponsored by: Real Truck
reprogram keyless entry
Old May 27, 2007 | 04:52 PM
esco24's Avatar
esco24
anyone know how to reprogram the keyless entry on a 02 f350 remote just stop working changed the battery no luck parking lights flash when i lock the door man.
Old May 27, 2007 | 05:02 PM
F250_'s Avatar
F250_
WELCOME TO FTE!!!
I just bought 4 new remotes and had to go through the procedure to get them working. I'm in my place of work at the moment, but I have the written instructions in my glove box. If you can wait, I can get it written up ofr you early this evening, probably by about 8pm central time.
In the meantime, you can try what I have stored in my (sometimes faulty and rather short lifespan) memory banks. You don't have anything to lose by trying.
READ thoroughly through all steps before trying it out.
1. Get in the vehicle with the doors unlocked and the doors closed.
2. Insert your key into the ingnition.
3. Eight times, cycle the ignition switch ON and OFF (WITHOUT starting). NOTE: you have to do this quickly within 10 seconds, and the LAST time, you have to leave the ignition in the ON position.
4. The door locks will cycle once to confirm that your in the programming mode.
5. Press any button on your remote.
6. Turn your ignition back to the OFF position and the locks will cycle once again indicating that you have left the programming mode.
You should be good to go... I think. If you try this and it works, post a reply back so I won't dig out the instructions unnecessarily. I'll check back in here before I leave work at 6-6:30 PM.
Old May 27, 2007 | 05:24 PM
esco24's Avatar
esco24
hey no luck maybe im doing something wrong
Old May 27, 2007 | 06:19 PM
esco24's Avatar
esco24
tried it again it worked i told you i must have did something wrong. thanks again for your knowledge. the website freakn' rocks
Old May 27, 2007 | 07:14 PM
F250_'s Avatar
F250_
Great!! Maybe my memory isn't quite as bad as I have been thinking! LOL.
Glad it worked for you.
This site is absolutely awesome. I've saved a lot of money and learned more tahn I ever thought I could in such a short time here.
Old May 27, 2007 | 07:36 PM
wiingnut's Avatar
wiingnut
Your right Esco! This website is the best. There is so much valuable information to be had. Welcome and enjoy your stay
61 uni
Jan 30, 2010 02:19 PM
Happy-Hoppie
General Diesel Discussion
Jan 3, 2007 06:54 PM
jbookrun
Dec 8, 2003 04:55 PM
JB7
1978 - 1996 Big Bronco
22
Dec 3, 2003 09:58 PM
dheitz
Sep 10, 2000 11:13 PM
