General Diesel Discussion
Keyless entry
Old Dec 14, 2006 | 08:00 PM
Happy-Hoppie's Avatar
Happy-Hoppie
Smile Keyless entry
I need help locating the computer modular for a 2004 F-350 Diesel 4x4 so I can reprogram the keyless entry key pad.
Old Dec 14, 2006 | 09:03 PM
EnviroCon's Avatar
EnviroCon
Above the transmission hump, against the firewall, behind some white "foam-like" material. You can see the front of the module by using a mirror and a flashlight. Good luck.
Old Dec 16, 2006 | 07:31 PM
Ruger01's Avatar
Ruger01
Remove the panel under the steering wheel. Look to the right and up under the white foam. You will see a white module with the numbers you are looking for. You may need a flashlight. You can also do a search on this web site and get more detailed instructions.
Old Jan 3, 2007 | 06:54 PM
Happy-Hoppie
Thanks Ruger01 was right there in frint of me took out the drink holder and the pannel you mentionrd and could read it large as life. thanks again
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
2Wise4aGM
Sep 19, 2010 04:12 PM
95Ford4x4
Nov 6, 2009 05:18 PM
loner
Electrical Systems/Wiring
Jun 11, 2002 02:43 PM
