1966 - 1977 Early Broncos
351 windsor HO?
Old Jan 11, 2003 | 09:59 AM
33bronco's Avatar
33bronco
351 windsor HO?
I was wondering what kind or ford cars or trucks came with a 351w HO from 1980 to 1986 before fuel injection. I was also wondering if a 351 w HO or a 1973 351c m code will fit in a 1973 bronco with a C4 trans. What is also the best auto trans to use with a 351, Aod, C4, Oor a C6.
Old Jan 12, 2003 | 07:23 PM
Chuck 6083's Avatar
Chuck 6083
From: Where they take the census by counting the appliances on the front porch and multiplying by five
351 windsor HO?
Welcome to FTE 33 Bronco!
While I don't know if there were any 351H.O. (windsor) before fuel injection,(barring the '69, not H.O. per se) I can tell you that a 351w or the 351c will fit in your bronco without a problem. The 351w may be a little easier swap.
As for trans, unless you're wanting an overdrive, stick with the c-4. I'v always gotten great service with them.
My .02
Again, welcome!
Chuck
Old Jan 12, 2003 | 10:36 PM
RCrawler's Avatar
RCrawler
351 windsor HO?
The 351HO was originally a Cleveland family engine, built around 71-73.
The 351HO Windsor was built in the mid 80's for pickups. It is a factory 4 bbl motor with a slightly more aggressive cam than the standard 351.
The 351C can be swapped into a Bronco. However, it is not a straight forward swap. Engine mounts are different. You would also need custom headers because there are not any off the shelf parts available.
The 351C is not a very good engine for low speed four wheeling. The heads are designed to make power at high RPM's and are pretty lazy down low.
The Windsor is a much easier swap. With the exception of some minor details, it will drop right in place of the 302. You can also build a Windsor to make serious torque, or able to make horsepower at 7000 RPM, or a combo of both. The aftermarket support for the Windsor is much better too. Plus, factory EFI is a easy bolt on.
As far as the trans, it depends what you want. The C6 is the stoutest. The C4 can be built into a strong and durable unit. The AOD has a reputation of being weak. It can be built to last, but is more expensive to do so, though it will never be as strong as a mildly built C4 or C6, in my experience.
Jason
Old Jan 12, 2003 | 10:48 PM
RCrawler's Avatar
RCrawler
351 windsor HO?
Fordtough94
Apr 26, 2009 04:42 PM
analogkid455
1978 - 1996 Big Bronco
Jul 11, 2007 10:00 AM
the lloyd wards
Mar 7, 2003 05:50 PM
cjben
Feb 25, 2003 07:46 PM
bigfordman70
May 26, 2001 09:01 PM
