Yup another DP thread
Old May 27, 2007 | 12:02 AM
powerstroked162's Avatar
powerstroked162
Do you have stock sticks in your truck?
Cowboy Steve
Old May 27, 2007 | 12:47 AM
crapr6's Avatar
crapr6
Cowboy Steve
What do you mean by stock sticks?
Old May 27, 2007 | 04:05 AM
powerstroked162
Stock injectors?
Cowboy Steve
Old May 27, 2007 | 10:30 AM
crapr6's Avatar
crapr6
Stock injectors?
Cowboy Steve
Yes stock inj's, HPOP,and Turbo
Have 4in dp to 5in straight pipe, AFE stg 2 intake w/ proguard filter,boost anhillator (sp?), trans/boost/egt gauges, 6liter trans cooler (waiting for bts valve body to come to install all at once, Mag hytec trans pan (8 extra quarts of fluid) and Mag Hytec rear cover (dana 80).
thats about it for now time PMS kicks in again and then its time for BIG OIL..
Erik
Old May 27, 2007 | 03:50 PM
crapr6's Avatar
crapr6
little update..no the trans is fine still, but i was on the GSP (main interstate in NJ) today and noticed the boost gauge stop working. I pulled over and notice the boost gauge line where i T it into the MAP line fell off. Got home and rip tie every line now and its all good. Dam boost pressure blowing of all my lines. LOL
Erik
Old May 27, 2007 | 04:03 PM
Luca Brasi's Avatar
Luca Brasi
What is a BTS VB?
Old May 27, 2007 | 04:19 PM
powerstroked162
Originally Posted by Luca Brasi
What is a BTS VB?
Brian's Truck Shop, Valve Body. Tranny parts is what it is. BTS specializes in the ford trans area.
Cowboy Steve
Old May 27, 2007 | 06:01 PM
erik_bishop's Avatar
erik_bishop
What is a BTS VB?
VB is a Valve Body in your tansmission, determines how your tranny shifts and when it shifts
BTS makes them, better ones than stock.
http://www.btstransmissions.com/default.htm
item you should buy if you increase HP in your engine.
Old May 28, 2007 | 11:55 PM
dirty1's Avatar
dirty1
I might as well jump on this one. I installed my DP on Sunday and the VB is going in on Wednesday. I can not wait!!!!
Old May 31, 2007 | 08:44 PM
crapr6's Avatar
crapr6
UPDATE if anybody cares. I got the BTS VB today from UPS and installed it tonight with the 6liter trans cooler and Schaifer(sp?) fluid. Man does that VB make a big diffrence in the shift pattern and firmness! The DP chip was burned for the BTS VB and i really like how the 2 work togeather. The fluid and cooler change also made a big diffrence in Temp. Normally my Trans temp would be at ambeint temp plus 100 degrees so like yesterday it was about 80 degrees out so trans temp was at about 180 degrees. Well on the drive home tonight after installing the VB at the shop the outside temp was 70 degrees and the trans temp never went over 125 degrees! Thats 55 degrees cooler running in driving the truck the same way i do all the time. I mean the stock trans cooler on my truck was 1/3 the size of the 6 liter 31 row trans cooler!!! Great stuff.
Erik
crapr6
23
Mar 31, 2009 09:47 AM
Erik Sink
27
Oct 1, 2008 02:25 PM
crapr6
20
Jun 11, 2007 06:28 PM
crapr6
13
May 21, 2007 02:39 PM
hdman6
15
Feb 15, 2007 02:54 PM
