dash cluster
Old May 25, 2007 | 11:59 PM
lucky no. 7's Avatar
lucky no. 7
dash cluster
just wondering how many bulbs are in a 68 dash cluster, also will a 68 cluster even work in a 72? if i remember right a 72 cluster is plastic on the back, not sure if it hsas a printed circuit or not though, i know one of yall will be able to fill me in on this, reason in ask is cause i have both styles, the 72 one is ok but the 68 is immaculate, also do they both have the same quantitiy of dash lights in em, thanks
Old May 26, 2007 | 12:13 PM
Fritolay's Avatar
Fritolay
the 72 has a printed circuit it is 4 light not including turn signal bulbs if i remember right. the electrical probably will not play nice together but you should be able to use the bezel. hope this helps
Old Jun 8, 2007 | 09:59 PM
orich's Avatar
orich
71 & 72 had the printed circuit. 70 and down has a wiring plugs, There not the same as 71 & 72
Old Jun 9, 2007 | 06:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by orich
1970 71 & 72 had the printed circuit. 70 1969 and down has a wiring plugs,There not the same as 70 71 & 72
ALL 1970 and later F100/350's have a printed circuit. 1970 uses a different printed circuit than 1971/72, which are the same. There are two types: With or without warning lights.
1970: D0TZ-10K843-A ~With Gauges / D0TZ-10K843-B ~ With Lights
1971/72: D1TZ-10K843-A ~ With Gauges / D1TZ-10K843-B ~ With Lights
MIKES 68 F100
Apr 25, 2014 03:03 PM
2003EXPY
16
Mar 23, 2013 10:25 AM
zukinut
13
Oct 9, 2011 02:46 PM
frankensteined_67
16
Aug 22, 2009 03:36 PM
wintremute
Apr 15, 2006 12:06 AM
