3 on the tree
Old May 27, 2007 | 01:45 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by uriah
Cool, that's likely it. I don't know why I didn't do it when I rebuilt the engine and trans...
Easy one. :)
"time constraints, real or imagined" -alvin
"nothing is hard to do, just some things take longer than others" -my best friend
Took me a few months to do my ring and pinion. :)
"while I have the axle out, I might as well..."
1) re-arch the leaf springs! :)
2) drill the leaf springs to accept plastic pads
3) change mind, fix my "damage" and install grease zerks instead
4) weld up cracks in the frame around one shock mount
5) etc
(at least two dozen that don't include axle-inerds;)
Alvin in AZ
Old May 27, 2007 | 08:43 PM
76supercab2's Avatar
76supercab2
Originally Posted by dionysius
I have a 1979 F350 Supercab and it has a strangeness to it when shifting. It sounds somewhat like the above symptoms. Moving the shift lever through the gears feels stiff and clumsy and unnatural and the detents are not well aligned. I can certainly drive the thing fine but one has to be used to it. I am loath to let others drive it since they may screw it up. It takes some expertise to be sure you are really in D and not N. Once in D or N however all is fine.
Could this also be caused by the worn bushings in the column as stated above ??
Should I disconnect the levers to the trans from the column and decide if the stiffness is in the column or in the trans??
For your problem with the auto trany shifting, my money is on the shifter collar at the top of the column (the shift lever goes into it) is worn out. It is made out of cheap metal and is known to crack and fail. Best look into it now. Even if you are very easy shifting it, it wears out eventually. Not an expensive fix (unless you let it go and it strands you ). You do have to pull the steering wheel to get it though.
Steven Wiley
15
Jun 6, 2016 02:29 PM
stand-al0ne
WTB - Parts & other
Apr 25, 2016 12:36 PM
Mav'_BlueF100
Feb 13, 2016 11:47 AM
Sarah's 67F100
Dec 18, 2015 10:51 PM
lowridaz22
Jun 6, 2005 08:58 PM
