Tranny upgrade
Old Dec 17, 2015 | 05:01 PM
Sarah's 67F100's Avatar
Sarah's 67F100
Tranny upgrade
Working with an all-original F100 with a 240 6 cyl and 3 on the tree. Let's say I want to keep my 240 6 cylinder and upgrade the transmission to a more modern standard shift with minimum mods. What are the best options?
Old Dec 17, 2015 | 05:12 PM
ultraranger's Avatar
ultraranger
...never mind. You said Standard Shift.
Old Dec 17, 2015 | 05:14 PM
Sarah's 67F100
Yes, that's an awesome upgrade. Thinking about that for my 69 Bronco. However, if I want to stay manual, what is the least mod requiring manual tranny upgrade? Is the Mazda 5spd a good option?
Old Dec 17, 2015 | 05:18 PM
HIO Silver's Avatar
HIO Silver
Long bed or short bed?
I guess in the end it doesn't matter but a Tremec T5z behind a lil 240 should be fine.
Old Dec 17, 2015 | 07:20 PM
Ford_Six's Avatar
Ford_Six
ZF from an 88-96 F250 with a 300, they had an external slave cylinder that can be removed. You'll need to make a custom pushrod to go from the Z bar to the clutch fork, but it should be fairly straightforward. The M5R2 five speed is stout enough, but has an internal slave requiring a hydraulic clutch setup. I have added a hydraulic clutch on my truck, as the 7.3 does not have a mount for the Z bar, it's fairly easy but is still a mod.
Old Dec 17, 2015 | 09:45 PM
anthony myrick's Avatar
anthony myrick
there are some top loader 3 spd ODs that will bolt right up
the only 2 mods will be the floor shifter hole and shortened driveshaft
Old Dec 18, 2015 | 02:27 AM
351Cleveland C4's Avatar
351Cleveland C4
The ones I know of have been mentioned already. With the little 240 though, I'd say go with the light weight T5.
Old Dec 18, 2015 | 09:35 AM
Sarah's 67F100
So the Mazda and the T5 will bolt up to the 240 with out adapter, mod required for Hydraulic clutch, floor hole and shorter drive shaft. Top loader behind a 300 six is bolt-in replacement with either a mod for hydraulic clutch or remove external slave and fab up a clutch adaptation. Am I missing anything?
Old Dec 18, 2015 | 10:50 AM
Rasputin53's Avatar
Rasputin53
The T5 I believe will put the shifter right in front of the bench seat. There is a GMC version used in the S-15 (Not S-10) that has the shifter location at the front of the tailshaft housing right behind the main case. One would have to swap the tailshaft housing at a minimum onto the Ford version of the T5 as the GMC main case has a different bell pattern at the four ears.
And a T5 is nicely geared for a straight 6's torque curve.
Old Dec 18, 2015 | 10:59 AM
Sarah's 67F100
Which Mustang T5 transmissions work?
Old Dec 18, 2015 | 12:04 PM
Rasputin53's Avatar
Rasputin53
You will want a World Class version from a V8, and not a 4-banger.
Here's a good link:
T5 History in Ford Mustangs with specifications for World class and non-World class T5's Modern Driveline
Old Dec 18, 2015 | 03:30 PM
Sarah's 67F100
Here's a good link:
Thanks for the link, great info. Maybe time to hit pick n pull!
Old Dec 18, 2015 | 10:51 PM
HIO Silver's Avatar
HIO Silver
Here's thread in Fordification on the same subject...
240 6cyl t5 swap - The FORDification.com Forums
my79f
Oct 23, 2006 08:06 PM
Dutch123
1978 - 1996 Big Bronco
Sep 15, 2005 09:08 PM
Fordbronco69
Aug 10, 2004 09:58 AM
gentleben26
Jun 22, 2003 11:07 PM
