1978 - 1996 Big Bronco
Help!!! I need a clue!!
Old Dec 20, 1999 | 07:49 PM
Don's Avatar
Don
I have a 90 fullsize bronco.....tonight i put it into 4wd....after i took it out....i backed up to disengage the hub....as i left my shop and pulled out of the parking lot taking a left.....i heard a loud clunking noise and the steering was very hard....so i pulled into the parking lot next door and repeatedly tried backing up thinking the hubs were still engaged. I pulled out went down the street and got on the highway.....while driving i noticed the steering was way more tight ........as you steered right and returned the wheel to center....you'd have to put effort into moving the wheel back over. When taking a corner...the wheel wouldn't return to center , i have to physically move it back.....I don't know what it is really....but what ever it is happened all in the sudden after i used 4wd......are the hubs stuck locked in??? If so, how the hell do i disengage them???
Old Dec 21, 1999 | 07:58 AM
Chuck P.'s Avatar
Chuck P.
One way to check if they are still engaged is to lift one of the front tires and see if the driveline turns-if it does then they have not unlocked. Sorry, can't help with how to unlock them other than to check the engagement mechanism or disassemble the hubs to see what's going on in there, run manuals myself, hopefully someone else can help with that end. Chuck P.
Old Dec 21, 1999 | 05:40 PM
Don's Avatar
Don
i pulled out of my garage this moringing and noticed i wasn't having the problem anymore. I love when ##### fixed itself....hopefully it don't happen again......i think the hubs were just stuck and when i backed out this morning they released
Old Dec 22, 1999 | 07:33 AM
Chuck P.'s Avatar
Chuck P.
Maybe they were just lettin' you know they would like exercised more often!! Happy to hear they "fixed" themselves, Chuck
Old Dec 28, 1999 | 01:20 AM
Superdave's Avatar
Superdave
As the past owner of the same vehicle you have, the hubs are probably going to puke anytime. My autolocking hubs failed when we had our first 6 plus inch snowfall last winter, and they only acted up once before they failed. I replaced them with lock outs the next afternoon.
Old Jan 1, 2000 | 09:47 PM
eric_1's Avatar
eric_1
don, you don't need a clue, you need manual locking hubs, warn makes a nice set for about $80 which is a lot cheaper than getting towed. do yourself a big favor and replace those auto's they will fail at the worst possible time. it only takes a couple hours to change them, its fairly easy, locking and unlocking takes about 15 seconds and you know when your in and when your out.if you decide to do it and have any problems post another message i'll walk you through. e
Old Jan 3, 2000 | 10:55 PM
Don's Avatar
Don
how much work is actually entailed in having to change of the autos to manuals. I'm not really an auto mechanic......i work on power equipment and commercial equipment for the most part.......but i am cable of doing the job, as long as i dont' have to worry about something terrible happening and having to have it towed and what not
Old Jan 4, 2000 | 01:12 AM
Superdave's Avatar
Superdave
Don, its not that big of deal to change the hubs. Most lockouts come with complete instructions to change them. The set I bought had instructions in them to change from auto locking hubs to the manual hubs. If you can work on stuff period you can change them just fine. You'll need some snap ring pliers, bearing nut socket, allen wrenches,a thin flat bladed screwdriver to pop the out snapring just inside the bearing hub right behind the autolocking hub. I also bend a couple of nails to look like an L to reach in the bearing hub to get the bearing nuts and bearing nut lock ring out. I think the auto's have torx head screws if I remember right. I'd be getting rid of those hubs before they get you in trouble, and they will!! Like the above post said no more guessing if there locked, if the weather is bad just lock them in before you leave then all you have to do is put it in four wheel drive when you need it. It won't hurt it to have the hubs locked and waiting.
Old Jan 5, 2000 | 04:37 PM
Phillip Guidry's Avatar
Phillip Guidry
shadylemon1
Apr 18, 2019 02:29 PM
M88
Sep 3, 2010 07:40 PM
BroncoPimp94
Feb 9, 2010 06:45 PM
Nate1
May 27, 2004 07:24 AM
ab_slack
Bronco II
Jan 7, 2003 06:40 AM
