Sponsored by: Real Truck
Clunking / Shaking when turning ?
Old Sep 3, 2010 | 03:49 PM
M88's Avatar
M88
Relatively new development.
I usually run one month with hubs in, one month without, etc. I guess running with the hubs locked in uses a miniscule amount of gas more so I try to avoid doing it all the time.
Wednesday, I put the hubs in and I noticed the steering wheel doing some funny things when returning to center ... it would turn a bit, then stop, then turn, then stop.
Next, I noticed that when I turned (going down the road or in a parking lot), I could get a clunking and slight shaking. Moreso noticeable when turning left.
Finally, I realized something wasn't entirely right. I pulled over and the lug nuts were a bit lose and I unlocked the front hubs at the same time. Probably should have waited to see if the lugnuts fixed it.
Anyway, I locked them again today and it is clunking when I'm turning.
  • Clunks / Shakes with hubs locked in when turning
  • Does not with hubs locked out
I can confirm that it is not stuck in 4 wheel drive. The front end on this thing is real real rusty so it's probablyt something with that.
Any suggestions?
Old Sep 3, 2010 | 05:47 PM
bpounds's Avatar
bpounds
Dry U-joints.
Old Sep 3, 2010 | 06:32 PM
M88's Avatar
M88
What would have to be done to remedy this? I probably should have ran with them in more often.
We've had a lot of 4x4s with solid front axles and this is the first one to have this problem.
Old Sep 3, 2010 | 06:45 PM
bpounds's Avatar
bpounds
Did you ever lube them? The front U-joints are the only zerks on the whole truck from the factory. Kind of tells you something, no?
If that's what it is, you just need to replace them. You could try some grease first, to see if they will free up.
Old Sep 3, 2010 | 06:49 PM
M88's Avatar
M88
I don't actually service the truck, we bring it to the dealer to get service (yeah I know but if they can do it for the same price ... ) and they lube the steering arm, ball joint and some other stuff.
Didn't know the U joints were greaseable. I may try some ATF ... something lightweight ... then move on to grease.
Old Sep 3, 2010 | 06:55 PM
bpounds's Avatar
bpounds
Keep in mind that it could be other things too. Like needle bearings, fubar'd locking hubs, even ball joints.
Old Sep 3, 2010 | 06:58 PM
bpounds's Avatar
bpounds
Oh, almost forgot to add, the U-joints are the ONLY thing under there that they can grease. Everything else is sealed, so they don't bother even looking.
Old Sep 3, 2010 | 07:14 PM
M88's Avatar
M88
Do you mean the U joints on the axle or on the driveshaft? I'm thinking the ones on the axle
It rides perfect with the hubs unlocked, seems like ball joints would be all the time type of deal. My Taurus has bad ball joints and this doesn't do any of the stuff that does. Granted, slightly different suspension setup!
Needle bearings and f-d up locking hubs could very well be the problem.
I have also noticed I get a noise coming from up there too with them in.
Interesting. I'll be greasing them, then. I have about 500 tubes in the garage!
Hopefuly I can report back later on with some results!
Old Sep 3, 2010 | 07:40 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Dry U-joints.
^^^this^^^..
that would be my first place to look at/suspect
yea he's talking about the U-joint on teh stub axles..NOt the driveshaft..
Tugly
Aug 15, 2016 10:58 AM
mscott
Apr 22, 2015 04:24 PM
Truck Guy99
May 27, 2014 01:14 PM
BroncoPimp94
Feb 9, 2010 06:45 PM
dustys7.3psd
Jun 17, 2009 01:47 PM
