What engine is this?
Old May 23, 2007 | 10:06 PM
bobj49f2's Avatar
bobj49f2
I don't know differences between the modern engines just by looking at them, I know a little more about the flatties. A person who I have been coresponding with via email has a '49 F-6 with this engine in it and we're wondering what engine it is. I think the manifold are Ram Horns?
Old May 23, 2007 | 10:09 PM
mechmagcn's Avatar
mechmagcn
Looks like a 283 or 327 Chevy to me.
Old May 23, 2007 | 10:12 PM
havi's Avatar
havi
I'll have the Roast Duck
dist in the back means it could be dodge or Chevy, but odds are it's a dodge 318 by looking at the color blue. But I'm not too familiar with the older engines. What is the cast number and firing order?
Also the big "rib" behind the thermostat housing.
Old May 23, 2007 | 10:19 PM
bobj49f2's Avatar
bobj49f2
I have no idea, the guy just sent me the picture. I told him I was going to post the picture here and let you guys have a look at it. Maybe he'll chime in on more info.
Old May 23, 2007 | 10:26 PM
53fatfndr's Avatar
53fatfndr
I'm thinking that's a Ford Y-Block, and I'm not sure on the size. Y-Blocks have the dizzy's in the back. Look at the shape of the heads on that block, it's a "Y", and the exhaust manifolds have the ram horn look, too. Here's a link on some Y-Blocks.
http://www.ford-y-block.com/enginepics.htm
Old May 23, 2007 | 10:29 PM
Kusto's Avatar
Kusto
Any chance of getting casting numbers off the block. If it is a chevy then he can easily get the numbers by pulling the tranny access panel and record the numbers off the rear of the block on the drivers side between the head and the bell housing on the transmission.
If you get the numbers and post them it will be easy to determine the size and year from the casting. Also if possible get the casting numbers from the front of the head on the passenger side and this will tell you if they are a performance head vs a standard head.
Old May 23, 2007 | 10:31 PM
havi's Avatar
havi
don't Y block distributors come out an angle? This one's straight up and down. Again, I claim to be no expert.
Old May 23, 2007 | 10:34 PM
pcmenten's Avatar
pcmenten
That is, without doubt, either a Chevy 283 or a Chevy 327. Clues; Rochester carb, valve covers with four bolts, generator, not an alternator, oil filler/breather in intake manifold. Note the 'rams horns' manifolds, probably a truck engine.
Old May 23, 2007 | 10:40 PM
53fatfndr's Avatar
53fatfndr
Hmm, good point, and I'm no expert either. I just see blue paint on an engine in a ford truck that is Y shaped and I think Ford. I have never owned a Y-block or a chevy engine, so I'm probably wrong on this one then.
Old May 23, 2007 | 10:44 PM
bobj49f2's Avatar
bobj49f2
I just got more information on the engine.
Valve covers say "Ch****let" , I couldn't make that out in the picture.
Firing order is 18436572
Old May 23, 2007 | 10:49 PM
havi's Avatar
havi
makes sense. the red peeling through the blue. I couldn't make out chevrolet on it either.
Old May 23, 2007 | 11:08 PM
kooper909's Avatar
kooper909
A few more giveaways:
The Y-block oil filler points the other way. The water outlet is mounted on the front and points up, rather than mounted on top pointing forward. The Y-block also has a large cast timing cover. You can tell this is a Chevy because of the visible space between the water pump and the timing cover.
Old May 23, 2007 | 11:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Y-blocks have nuts in the middle of the valve covers.
RUSTY50F1's Avatar
RUSTY50F1
Looks just like the 283 that I had in a 55 chevy. Look at the front of the heads and see if they have a half moon on them or a upside down V if it's a V it's a 327 with power pack heads. .........RUSTY
Old May 24, 2007 | 12:25 AM
pcmenten's Avatar
pcmenten
The water pump looks like the short style, which would also lean towards an early Chevy 283/327 instead of a Chevy 350 or late 283/307/327. The short water pump was used on some later Corvettes, but mostly on early Chevy small blocks. Also, the heads don't seem to have accessory bolt holes on the ends.
