I have a 1977 F150 that I thought had a 400 in it, according to the VIN. When I got underneath it however, it was plain to see that it wasn't the stock motor. I had a hard time finding codes for the block, but I found two:
D4TE - located by the pass. side front freeze plug
6A29 - located by the oil filter
Can anyone help me figure out what motor I have in my truck?
If there's another set of numbers that I'm missing let me know.
Hmm...where else should I look? I'm not sure I know what suffix your talking about. It has 5 valve cover bolts, 2 on the bottom and 3 on the top. Thanks, keep the info comin!
With that D4 casting number, it's an FE 360 or 390, nothing else Ford made had 5 valve cover bolts from this time. You might look at the base of the dizzy, just below the rim of the cap...there's are Ford ID numbers there, like: D6TE-12127-AA. Find something like that, and those numbers will ID what the dizzy is and what it was used on. Also look for a carb number, triangular shaped tag on top of carb...and post the VIN the truck might be a 1976. 1973/77's look almost identical.
