'77 F150 Engine Code Help
Old May 23, 2007 | 06:25 PM
classic4x4's Avatar
classic4x4
Exclamation '77 F150 Engine Code Help
I have a 1977 F150 that I thought had a 400 in it, according to the VIN. When I got underneath it however, it was plain to see that it wasn't the stock motor. I had a hard time finding codes for the block, but I found two:
D4TE - located by the pass. side front freeze plug
6A29 - located by the oil filter
Can anyone help me figure out what motor I have in my truck?
If there's another set of numbers that I'm missing let me know.
Thanks
Old May 23, 2007 | 06:30 PM
Mil1ion's Avatar
Mil1ion
That truck engine was designed in 1974 and the block itself was cast January 20 /1976.
You didn't give me the suffix after 6050 - ? so I am asking myself what engine was designed for a truck in 1974 ?
How many valve cover bolts ?
Old May 23, 2007 | 07:39 PM
classic4x4's Avatar
classic4x4
Hmm...where else should I look? I'm not sure I know what suffix your talking about. It has 5 valve cover bolts, 2 on the bottom and 3 on the top. Thanks, keep the info comin!
Old May 23, 2007 | 07:48 PM
Jermafenser's Avatar
Jermafenser
FE engine.
Old May 23, 2007 | 08:01 PM
Mil1ion's Avatar
Mil1ion
Must be a 360.
You are going got have to measure the stroke or ID the crankshaft to know for sure.
The Suffix I mean should be an A or B
and read like this
D4TE-6050-A
D4TE-6050-B
as shown here
Old May 26, 2007 | 02:47 PM
mattri's Avatar
mattri
5 bolts for the fe, double check by looking at the dizzy, doeas it go through the intake?
Old May 27, 2007 | 08:27 AM
classic4x4's Avatar
classic4x4
No it doesnt go through the intake, the intake manifold goes around it
Old May 27, 2007 | 08:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
With that D4 casting number, it's an FE 360 or 390, nothing else Ford made had 5 valve cover bolts from this time. You might look at the base of the dizzy, just below the rim of the cap...there's are Ford ID numbers there, like: D6TE-12127-AA. Find something like that, and those numbers will ID what the dizzy is and what it was used on. Also look for a carb number, triangular shaped tag on top of carb...and post the VIN the truck might be a 1976. 1973/77's look almost identical.
Old May 27, 2007 | 11:03 AM
classic4x4's Avatar
classic4x4
I'm sorry, it does go through the intake manifold. It gets really shallow.
Old May 27, 2007 | 11:45 AM
Mil1ion's Avatar
Mil1ion
Yes but you will need to measure the piston stroke or Ident the crankshaft to know for sure if it is a 360 0r 390.
Jkhuge
2004 - 2008 F150
Sep 28, 2017 03:12 PM
4.9LOldFordTruck
Dec 14, 2015 08:36 PM
Amish Ford
1997 - 2003 F150
Dec 4, 2015 05:11 PM
Beav93
Jan 14, 2012 08:18 PM
Drivingmad44
1997 - 2003 F150
Jan 19, 2010 09:30 AM
