What injectors for an 88 302 in an F150???
Those will work, but I think you have a lot more to learn before you attempt to upgrade your engine.
First off, your engine is speed density and therefore doesn't have a mass air flow sensor. Second, adding bigger injectors will only help you if you are somehow exceeding the capacity of the stock injectors. If your engine is otherwise stock, bigger injectors won't do a thing. You would also have to have a heavily modified 302 (stroked, supercharged, etc) before you would need a mass air sensor - but again, you don't even have one.
Hell after having diesels for 14 years i am pretty much lost. The last gasser i had was carburated. Thanks for the help.................
fordman1954
04-05-2007 05:16 PM
