fuel pump part #
Old May 22, 2007 | 05:08 PM
bloomy63's Avatar
bloomy63
fuel pump part #
does anyone know the bosch part number off of the stock fuel pump?
Old May 22, 2007 | 05:11 PM
MAKO314's Avatar
MAKO314
if your in the need of a fuel pump I would recomend a Napa gold it's much cheaper and it's a Carter, it's what I have and it works great. I paid 220.00 I think the bosch unit was much more
Old May 22, 2007 | 05:20 PM
Kwikkordead's Avatar
Kwikkordead
The part number on the side of my old pump.
Bosch number: 0 580 464 074
Ford number:F81U.9350.AA
Old May 22, 2007 | 05:30 PM
bloomy63's Avatar
bloomy63
thanks for the "kwik" response
Old May 22, 2007 | 10:17 PM
jtharvey's Avatar
jtharvey
Check out this pump for a good upgrade over stocker: http://www.expressfuelpumps.com/bosc...ne-p-3805.html
It's still a Bosch pump, will fit in your factory pump mount, and will use the factory electrical connections. It flows 300 LPH (which I think is around 80 GPH) at 72.5 psi. You'll just need to get some different fittings for the fuel lines.
Old May 23, 2007 | 08:36 AM
Kwikkordead
That's basically the same pump that I modded into my truck with some different fittings on the ends of the pump.
Let me tell you that a good pump makes a HUGE difference. My truck used to fall flat above 2500 rpm and now it pulls hard beyond 3000.
You'll have to remove the rubber blanket that surrounds the factory pump to get it to fit in the mounting clamp. No biggie. It won't make it noisey at all.
Old May 23, 2007 | 06:17 PM
bloomy63's Avatar
bloomy63
That's pump i've been looking at. But on the bosch website here: the http://www.bosch-motorsport.de/pdf/c...mps/FP-200.pdf
It says that the output of this pump is greater than 200 lph (52 gph) at 5 bar (72.5 psi) part # 0580254044
Or that same pump which has been tested to flow 200 lpr at 8 bar (116psi) part # B261205413
I tried to research the flow rate of the factory pump at around 70psi to compare it to these and could not find any info on it. It sounds like the 0580254044 puts out more fuel than the stocker.
Old May 23, 2007 | 08:53 PM
Kwikkordead
Bloomy63 if you feel like modding in that bigger pump, let me tell you, it's well worth the effort in how much better the engine runs.
jacknewt
Jun 10, 2017 01:00 PM
GuitarJesus
May 17, 2016 04:15 PM
Crewcab Turbo
36
Mar 18, 2013 12:02 PM
terrytwin
Large Truck
Jan 5, 2012 04:02 AM
jdonovan
May 15, 2011 06:52 PM
