For NumberDummy
Old May 22, 2007 | 09:47 AM
F100Newbie's Avatar
F100Newbie
For NumberDummy
This question is aimed specifically at NumberDummy, although anyone else can chime in if they know. The VIN on my truck is F10AK8242XXX. What does this tell me? Can you tell me where to go to decode this if you don't have time to do it yourself?
Thanks in advance. If I could email you, I would.
Old May 22, 2007 | 01:47 PM
bertha66's Avatar
bertha66
F10 61-66 F100 2wd, A 66 240cid I-6, K built Kansas City, 8242xx built in Feb 1966.
Old May 23, 2007 | 08:17 AM
F100Newbie's Avatar
F100Newbie
Good info so far
Thanks Bertha. I appreciate the information. If I may ask a follow-up, in the stock version of that truck, what was the rear end?
Old May 23, 2007 | 08:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Late to the party again...
Ford 9 inch, prolly a 3.70-1 or 3.89-1 ratio. Post the rest of the numbers off the plate..it can be decoded here.
Old May 23, 2007 | 08:48 AM
F100Newbie's Avatar
F100Newbie
The full VIN is F10AK8242748. I haven't gotten underneath for any other numbers (part, engine, etc.)
Old May 23, 2007 | 08:51 AM
NumberDummy
I don't need that..look on the door face near the latch...that's where the VIN plate is. The numbers from the plate are what I'm asking about.
Old May 23, 2007 | 09:05 AM
F100Newbie's Avatar
F100Newbie
The door plate is missing. I had to go to the frame on the passenger side to find the VIN. Almost got my vehicle impounded for that little snafu.
Old May 23, 2007 | 09:33 AM
NumberDummy
Missing door plate, what else is new...
For the rear end info, look at the 10 bolts that holds the pumpkin (carrier) to the housing. The ID tag is at roughly 4 or 5 o'clock as you are looking at the front of the rear end. (The tag could be missing too, again that's nothing new).
Old May 23, 2007 | 11:00 AM
F100Newbie's Avatar
F100Newbie
Thanks. Will do when I get home tonight (maybe)
Old May 25, 2007 | 09:54 AM
F100Newbie's Avatar
F100Newbie
If it isn't a 9", what else might it be?
Old May 25, 2007 | 11:17 AM
bertha66's Avatar
bertha66
Some had the Dana rear end, these have a plate on the rear of the diff. the gears came out the back. The 9" the center section, with the ring and pinion comes out the front as a unit.
Old May 30, 2007 | 11:52 PM
6T6Shorty's Avatar
6T6Shorty
Spicer 38 3.73's
My 66 has that same diff.
Old May 31, 2007 | 09:16 AM
F100Newbie's Avatar
F100Newbie
I have a 44. Does anyone know the stock gearing of those rearends? Associated with that, what would a good gearing be for a 240/3 spd to increase the trucks drivability at around 55 mph? The motor is currently running pretty high RPM at those speeds and I would like to run those down a bit.
Thanks
Justin
Old Jun 1, 2007 | 05:11 AM
NumberDummy
I have a 44. Does anyone know the stock gearing of those rearends? Associated with that, what would a good gearing be for a 240/3 spd to increase the trucks drivability at around 55 mph? The motor is currently running pretty high RPM at those speeds and I would like to run those down a bit.Thanks
Justin
5 different ratios offered, and most Spicer (Dana) 44's from this vintage have locking rear ends: 3.31 / 3.54 / 3.73 / 3.92 / 4.09.
6T6Shorty: you have a Spicer what? No Spicer 38's used in 1961/72 Ford trucks. I never heard of, or have seen a Spicer 38 in any Ford truck.
MavSprint
Sep 24, 2013 10:08 PM
DutchB100
Jan 18, 2011 09:38 AM
ctubutis
May 29, 2009 12:26 AM
Rick_Fury
May 28, 2009 09:20 PM
John Morton
Jan 30, 2009 08:19 PM
