I didn't intend it to be a trick question. In looking thru the junk yard there seems to be a variety of frame configurations. The only 302/351 trucks I found that might fit still have the engines in place. Can't get a good look at the brackets with exhaust manifolds and pipes still in place.
Its a nasty job to remove the engine brackets with the engine in place. So, I'd like to be sure of the fit before I go thru that again.
I searched and found ND info on earlier perches, just nothing for the '81 I'll be working on.
ND, I need to find engine perches/brackets to mount a 351W in a 1981 2WD F150. Can you tell me the part numbers and possible donors? Jim
EOTZ-6028-D (replaced EOTZ-6028-C) Right & EOTZ-6029-D (replaced EOTZ-6029-C) Left .. Engine Supports aka towers/stands/perches.
1980/83 F100/150 255 / 1980/96 F100/250 & Bronco 302 / 1981/96 F150/350 351W
351W not available in F150/350's & Bronco's until 1981, not available in F100's. Largest available V8 in 1980/83 F100's: 302.
Same engine supports: 1969/79 F100 302 / 1975/79 F150 302 / 1977/79 F100/350 351M/400 2WD, but NOT the same as 1980 and later!
