Aerostar Ford Aerostar
*&*^%$# ignition switch!
Old May 21, 2007 | 03:25 PM
VanGo's Avatar
VanGo
For a long time the keys-left-in-ignition warning chime would continue after the key was out. You could jiggle it and it would stop. Now it's getting hard to rotate the switch to start the van. I'm worried about getting stranded!
At first glance this looks like a PITA to change. I need to consult the CD. Is this a dealer part?
Old May 21, 2007 | 07:09 PM
DOUG5G's Avatar
DOUG5G
Easy fix
Mine was doing the same thing. It isn't the entire Ignition. It was just the Ignition lock cylinder. $20. All I had to do was insert the the key turn it to run...but not start..then insert a small rod into the hole under the steering collumn. I used a streight clothes hanger. I pushed the little button that is inside the hole then pulled the lock cylinder out. I was simple!!!
It was funny how i nver noticed that hole before. Here is the thread from when I fixed it before!
https://www.ford-trucks.com/forums/4...=lock+cylinder
Doug
Old May 21, 2007 | 08:06 PM
Bear River's Avatar
Bear River
Former ******
There are some aftermarket units that are more durable than Ford's. We have one such unit in ours. They are not OE styled.
Old May 21, 2007 | 08:42 PM
VanGo's Avatar
VanGo
That's great news! I'm going to re=key the new lock for the old key
Old May 22, 2007 | 11:46 AM
VanGo's Avatar
VanGo
If you had a choice, which brand of switch would you buy? I need to call around for one today.
Thanks,
Old May 22, 2007 | 12:27 PM
sctrailrider's Avatar
sctrailrider
I'm on my third cylinder. Seems like I have to replace it every 100,000 miles. I just take what the Advance Auto parts guy brings to the counter.
Old May 22, 2007 | 12:29 PM
VanGo's Avatar
VanGo
I can live with a 100K lifespan
Old May 22, 2007 | 02:31 PM
96_4wdr's Avatar
96_4wdr
http://www.motorcraft.com/catalog.do
Poorman Automotive Warehouse
1400 E. Douglas Ave.
Wichita
KS,67214
Old May 22, 2007 | 03:11 PM
VanGo's Avatar
VanGo
They are about a mile from my house
Old May 22, 2007 | 03:42 PM
cookkd's Avatar
cookkd
I think the hardest part was removing the plastic shroud for access to the little hole......lol
Old May 23, 2007 | 08:00 PM
VanGo's Avatar
VanGo
This was soooo easy thanks to all of you. In fact, after I installed the new switch to make sure it worked, I removed again to get it re-keyed to match my original one.
I ended up with a Borg-Warner brand. It cost much more than the $15 unknown brand, but it gives me better piece of mind.
RBerry9511
Feb 7, 2020 04:31 PM
bigcrunch
Large Truck
May 8, 2016 11:52 AM
loganmick
16
Jul 11, 2015 05:09 PM
RedBoat
Jun 27, 2006 04:18 PM
ThomasDooley
Jul 12, 2003 03:56 PM
