Offroad & 4x4
body mounts rusted through
Old May 19, 2007 | 09:07 PM
captain p4's Avatar
captain p4
Two or three of my body mounts are rusted through, whats the best way to repair something like this?
The body is coming off as soon as I get a couple people over to help me lift it off, so I will be able to move the chassis around and have a clean shot at everything. Would you just weld plate on the frame and then cut through for the body mounts?
Old May 19, 2007 | 10:04 PM
bigun72's Avatar
bigun72
buy some cab mounts and stuff , do it right , dont rig it up
Old May 19, 2007 | 10:21 PM
captain p4's Avatar
captain p4
Well, its on a bronco and the rear body mounts are directly through the frame.. the frame has rusted around them, I can't replace the mounts.. because its the frame.
Old May 20, 2007 | 08:25 PM
captain p4's Avatar
captain p4
here's some pictures of the carnage.. I got the body off today with about 8 people helping. It's heavier than it looks!
Old May 20, 2007 | 08:35 PM
velcro7279's Avatar
velcro7279
I welded some plates on the front cab mounts on the frame of my F 150 that looked just like yours. It worked real good. Just get something at least as heavy as the frame. I think I use 11ga (which is 1/8") sheet metal. It was what I had on hand. If you don't care about show quality you can just put a plate on top of the frame and weld it in place. Should work fine.
Steve
Old May 20, 2007 | 10:08 PM
fishmanndotcom's Avatar
fishmanndotcom
get some plate and just weld over the hole (bigger the plate the better for more contact surface). i'd go with 1/4" if you can
-cutts-
Old May 25, 2007 | 10:15 PM
JeremyH's Avatar
JeremyH
Plate it!
I fabbed up some plate body mounts when I attached my 80's heap body to my 75 chassis....worked well.
Old May 26, 2007 | 09:14 AM
captain p4's Avatar
captain p4
I got the rest of the body mounts off and I only had one good one left and I also found out my d-shaft was missing a bolt and very loose.. it probably would've come off and took out at least a few things the next time I drove it.
Is there anywhere I can buy the cab mounts in the front that are riveted to the frame?
Old May 26, 2007 | 11:06 AM
MBBFord's Avatar
MBBFord
A junkyard.
Hope you like using a grinder, drill, and a big punch.
Got to hate rust.
Old May 26, 2007 | 12:42 PM
82F100SWB's Avatar
82F100SWB
Ford probably still sells them too....
Old May 28, 2007 | 10:23 PM
Hyperactive460's Avatar
Hyperactive460
try http://mtsalvage.com/, i know he's not a sponcer but he has alot of parts like your looking for that you ca't get anywere else...
Lane Locke
Dec 14, 2024 02:59 PM
jzzzake
Mar 27, 2017 03:41 AM
Harleydave00
Sep 16, 2016 04:11 PM
ryanhablitzel
Jan 16, 2013 11:29 PM
66F100Again
Nov 19, 2007 10:39 AM
