JAck points- E350?
Old May 19, 2007 | 03:29 PM
carrfamilynj's Avatar
carrfamilynj
JAck points- E350?
I have a 15 passenger extended Ford E350 van. I need to jack up the rear-can I use the rear diff. as a jack point, or will that possibly be damaged with all the weight? How about the axle tubes? The van weighs in at about 7500 pounds. Could I bend the axle tubes by resting them on jack stands? I need to rotate the tires so all four corners will be in the air at once.
Old May 19, 2007 | 06:40 PM
maples01's Avatar
maples01
The axle is the jacking point, the factory jack is designed to go under the axle between the ubolts under the leaf spring in the rear, front goes under the radius arm at the I-beam, one side at a time. You can place a floor jack under the pumpkin at the rear, jacking bot sides at the same time, as long as the jack is capable of handling the weight. Always use jack stands before getting under the van, be certain they are capable of holding the weight and placed under the frame, not body.
Old May 20, 2007 | 03:14 PM
rebocardo's Avatar
rebocardo
imo, Lifting all four wheels off the ground at the same time and removing all four tires at the same time is just an accident waiting to happen even using good jack stands.
Just do one side at a time.
Old May 20, 2007 | 05:06 PM
HAB's Avatar
HAB
Have had a van fall when an idiot tried to raise both ends at once to rotate tires. The fool almost lost his arm. Seen it done since but only with a drive on lift.
Old May 20, 2007 | 08:32 PM
carrfamilynj
Alright, all done. I jacked the rear with my new Michelin 3.5 ton floor jack, and put the 6 ton jack stands under the axle. Then I jacked the front one side at a time with a scissor jack, got them all rotated. So basically there were only three tires off the vehicle at once....The jack paid for itself already! The van was rock solid sitting on those stands.
Old May 20, 2007 | 11:16 PM
Club Wagon's Avatar
Club Wagon
This is bad advice! Especially on Econolines b/c the pumpkin is not in the middle & many Econolines might be carrying a load! In general practice, some rear axles assemblies have the tubes press fit into the pumpkin, they simply are not designed to support the weight if used as a jack point. There have been many cases where rear ends were ruined, requiring replacement, only b/c the vehicle was jacked up at the pumpkin! The cover can also get pranged doing this surprisingly easily, resulting in leakage that might not be immediately evident. Similarly front drive cars can easily have rear tube axles bent by lazy mechanics jacking at the center, also trailer axles.
Although I've seen people getting away with this as recently as last week, it is NOT A SAFE PRACTICE . Don't be lazy or foolish, be safe & secure.
Jack at each side under the springs or as close as possible.
Old May 21, 2007 | 05:43 PM
Fordcr's Avatar
Fordcr
Your Owner's manual advises NOT to jack under the pumkin also. I watch mine in the tire shop and make sure they don't.
Old May 21, 2007 | 10:34 PM
Club Wagon's Avatar
Club Wagon
Was not making it up, or offering my personal opinion on this AND was trying to make it clear the practice is hazardous on most vehicles & not just limited to Econolines' off center differential.
No conscientious mechanic should still be lifting any vehicle by placing a jack at the center of the rear axle. The warnings have been made abundantly clear.
Old May 23, 2007 | 07:19 AM
tradosaurus's Avatar
tradosaurus
Smile
When I buy tires I try to get a lifetime balancing and rotation (Discount Tire here in Texas).
The cost is minimal considering the life of the tires and a lot safer for me.
I think I tried rotating tires one time on a vehicle and it was my last.
scooterspal
33
Jun 15, 2018 10:57 PM
the winemaker
Jun 3, 2017 08:25 PM
FireEngineMike
1947 and Older Ford Trucks
Nov 9, 2016 08:52 PM
wales
Missouri Chapter
Dec 21, 2015 09:09 AM
t_dub
Oct 8, 2015 03:22 PM
