Jack Points
Old Nov 8, 2016 | 01:32 PM
FireEngineMike's Avatar
FireEngineMike
Jack Points
I did not get any responses to a forum search. What are the Ford recommended jack points for 1-1/2 ton trucks? Are axle tubes safe to support the rear of the truck (jack point/jack stands)? What about using a big floor jack to lift the truck by the frame?
Old Nov 8, 2016 | 08:29 PM
Joe777's Avatar
Joe777
Mike, I lifted the rear axle with a floor jack under the pumpkin, with a block of wood as a cushion, and then rested it on jack stands under the axle tubes. Don't know if this is the approved method but I haven't noticed any ill effects - so far. Bet that puts your mind at ease!
Old Nov 8, 2016 | 08:32 PM
Joe777's Avatar
Joe777
Note! My truck is just a cab/chassis so far. No real weight on the back end.
Old Nov 8, 2016 | 11:49 PM
GB SISSON's Avatar
GB SISSON
I tend to jack at the leaf springs and then put jack stands under the axle tubes. Done this for 40 years, never a problem. These are very tough trucks!
Old Nov 9, 2016 | 05:44 AM
FireEngineMike
Thanks for the responses. I bought a 6-ton bottle jack to carry with me and used Gary's method when we did the tire/wheel work. A friend used a bottle jack under the middle of the front axle to lift the front end of the department's truck; I wasn't that brave. We dropped the trucks onto jack stands in both cases. Was looking for validation or better method for the future. Thanks again.
Old Nov 9, 2016 | 08:52 PM
willowbilly3's Avatar
willowbilly3
Yeah, don't jack in the middle with a bottle jack. I've been doing it like GB for just as long.
rtcapo
Oct 24, 2017 03:27 PM
speakerfritz
Apr 27, 2015 11:29 PM
StumpPullerF1
Jan 18, 2011 04:13 PM
locknload223
Nov 26, 2007 06:48 PM
Flywest
13
Jan 16, 2007 01:51 PM
