I have a 15 passenger extended Ford E350 van. I need to jack up the rear-can I use the rear diff. as a jack point, or will that possibly be damaged with all the weight? How about the axle tubes? The van weighs in at about 7500 pounds. Could I bend the axle tubes by resting them on jack stands? I need to rotate the tires so all four corners will be in the air at once.
The axle is the jacking point, the factory jack is designed to go under the axle between the ubolts under the leaf spring in the rear, front goes under the radius arm at the I-beam, one side at a time. You can place a floor jack under the pumpkin at the rear, jacking bot sides at the same time, as long as the jack is capable of handling the weight. Always use jack stands before getting under the van, be certain they are capable of holding the weight and placed under the frame, not body.
imo, Lifting all four wheels off the ground at the same time and removing all four tires at the same time is just an accident waiting to happen even using good jack stands.
Have had a van fall when an idiot tried to raise both ends at once to rotate tires. The fool almost lost his arm. Seen it done since but only with a drive on lift.
Alright, all done. I jacked the rear with my new Michelin 3.5 ton floor jack, and put the 6 ton jack stands under the axle. Then I jacked the front one side at a time with a scissor jack, got them all rotated. So basically there were only three tires off the vehicle at once....The jack paid for itself already! The van was rock solid sitting on those stands.
This is bad advice! Especially on Econolines b/c the pumpkin is not in the middle & many Econolines might be carrying a load! In general practice, some rear axles assemblies have the tubes press fit into the pumpkin, they simply are not designed to support the weight if used as a jack point. There have been many cases where rear ends were ruined, requiring replacement, only b/c the vehicle was jacked up at the pumpkin! The cover can also get pranged doing this surprisingly easily, resulting in leakage that might not be immediately evident. Similarly front drive cars can easily have rear tube axles bent by lazy mechanics jacking at the center, also trailer axles.
Although I've seen people getting away with this as recently as last week, it is NOT A SAFE PRACTICE . Don't be lazy or foolish, be safe & secure.
Jack at each side under the springs or as close as possible.
Was not making it up, or offering my personal opinion on this AND was trying to make it clear the practice is hazardous on most vehicles & not just limited to Econolines' off center differential.
Originally Posted by Fordcr
Your Owner's manual advises NOT to jack under the pumkin also.
No conscientious mechanic should still be lifting any vehicle by placing a jack at the center of the rear axle. The warnings have been made abundantly clear.
