Sponsored by: Real Truck
Power windows problems
Old May 19, 2007 | 12:46 AM
Cold Man's Avatar
Cold Man
I have a 2002 F-250 super cab with power windows and my head hurts. Its my pasenger side window thats causing me trouble. i can get the window down but not back up. From the drivers side control panel, when i push the up button for the passenger side, the light on the button on the passenger side goes out but the window does not move. If i push the down button on the drivers side control panel for the passenger window, nothing happens.
From the passenger side control panel, if i push the up button, the light on the button on that side goes out but the window does not move. If i push the down button the window goes down.
Im not too sure where to start with this problem but i did check the fuses just to make sure and they were ok. Anyone with advise or even a wiring diagram would be great!
thanks
Coldman
Old May 19, 2007 | 11:41 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
It's time for new switches....Ford makes lousy window and door lock switches...Pretty easy to change and not too expensive. Buy 'em thru your regular dealer or order 'em from one of our sponsers....
Old May 19, 2007 | 12:58 PM
Clint40's Avatar
Clint40
At one time someone here did a backyard fix to the window motors or something. It was a cool way to fix your window motors if bad and you only had time involved. You may want to search.
Old May 19, 2007 | 01:36 PM
jake00's Avatar
jake00
I had to replace my switch, I think it was in the neighborhood of 100 bucks
Old May 19, 2007 | 07:46 PM
Cold Man's Avatar
Cold Man
Got it fixed up... i played around with it and a multi meter and in the end figured out there is a common wire between the drivers side and passenger side switches and that wire was broken on the drivers side in the connection tube! 3 hours later
Coldman
Jt00
1983 - 2012 Ranger & B-Series
Aug 19, 2015 09:33 AM
LARIAT 85
Mar 26, 2013 07:38 AM
fosterslager
Jan 8, 2012 12:49 PM
uscrpick
1978 - 1996 Big Bronco
Mar 1, 2007 10:29 PM
Dick7.3
Feb 12, 2007 05:22 PM
