Passenger window issue
Old Feb 12, 2007 | 01:30 PM
Dick7.3's Avatar
Dick7.3
The front passenger window only goes up and down from my (drivers) controll. I replaced the switch and it made no dofference.
Is there a relay or something i can check? If someone pushes the passneger button down and i push down on my control, the window does nothing, so there has to be some kind of connection still.. Thanks
Old Feb 12, 2007 | 05:22 PM
Cuda_jim's Avatar
Cuda_jim
According to the repair manual schematics the power to the RH window motor goes from the master switch (LH Door) thru the RH switch. The RH switch has it's own ground. The ground wire is light blue w/black tracer, and is terminal #8 on the RH switch. You need to see if that wire is grounded.
The fact that the window works from the LH switch means the power is getting to the motor through the RH switch so is must be the ground is missing from the LH switch.
Send me a PM with your email address and I will send you the schematic.
bigtexan99
Sep 13, 2017 08:46 AM
ugh3012
Jul 4, 2016 08:54 AM
bf5113x
Oct 19, 2015 07:02 PM
Jt00
1983 - 2012 Ranger & B-Series
Aug 19, 2015 09:33 AM
cableguy1224
19
Aug 4, 2009 12:24 AM
