1978 - 1996 Big Bronco
Reverse Window Motor
Old Mar 1, 2007 | 05:45 PM
uscrpick's Avatar
uscrpick
I just replaced the window motor on the passenger side of my 89 Bronco. I used a rebuilt motor from a Ford Dealer. I have done the driver's side before without any problems so I did not think I would run into any this time.
When I was done with my project I tested it with the passenger side controls and when I push th up button the window goes down. When I push the down button the window goes up. They same thing happens with the passenger window control on the driver's side. This did not happen before I replaced the motor. Why could this be happening? Is there something easy I missed or did they possibly rebuild the motor wrong.
Thanks for any help.
Old Mar 1, 2007 | 05:53 PM
shouldagotablazer's Avatar
shouldagotablazer
sounds like somethings backwards. have you double checked how you hooked it up?
Old Mar 1, 2007 | 06:30 PM
cfrives3's Avatar
cfrives3
Same just happened to me-cut the two wires, swap em-problem solved.
Old Mar 1, 2007 | 09:02 PM
uscrpick's Avatar
uscrpick
The electrical connection only goes one way so I know I hooked it up correctly. I will probably cut and switch the wires. I hate to take the panel off again.
Old Mar 1, 2007 | 09:37 PM
surewhynot's Avatar
surewhynot
It happened to me once. I just cut and swapped the wires also.
Old Mar 1, 2007 | 10:29 PM
dwoodler's Avatar
dwoodler
Don't cut the wires! The plastic plugs have little plastic pins on the inside that when you depress them - the wire connector on the end of the individual wires then slides out, switch them around and slide them back in. It'll click once its in far enough.
Woodler
Jt00
1983 - 2012 Ranger & B-Series
Aug 19, 2015 09:33 AM
lightningdan
May 15, 2014 11:04 AM
fosterslager
Jan 8, 2012 12:49 PM
rjeremyj
Nov 22, 2010 08:43 AM
mikren
1997 - 2003 F150
28
Aug 22, 2009 09:39 AM
